Can I Still Stain After Wipe-on Poly? - Painting - DIY Chatroom Home Improvement Forum
Old 03-06-2011, 12:19 AM   #1
Can I still Stain after wipe-on Poly?
So I sanded, painted and distressed my vanity table. I loved how it look so I put on two coats of wipe-on poly. Now I'm thinking that I should have stained it a little to make it look more weathered, can I still stain after I have already used poly? I was thinking maybe I could sand it all down with 220 fine grit, stain and then poly again?
jennyusmc is offline   Reply With Quote
Old 03-06-2011, 06:46 AM   #2
DIY staff
Rewards Points: 7,174
The poly will prevent the stain from reaching the wood---Have you thought of a glaze?
Burnt amber mixed into a clear glaze and then wiped off might give you the antiqued look without needing to strip the vanity again.--Mike--
Old 03-06-2011, 09:02 AM   #3
the Musigician
DangerMouse's Avatar
orrrrr.... you could try using a stain/varnish combo product. However, to stain the WOOD, you'd need to strip it first.
DM
Old 03-06-2011, 12:29 PM   #4
Thanks!
Mike - I have gloss, I actually have a Tea-Stained color that looks pretty nice, do i need to sand it a little to prep the wood? And after I finish glazing, should I use wipe-on poly again?
Thanks again!
Old 03-06-2011, 01:29 PM   #5
DIY staff
You will have to experiment a bit--I think another coat of wipe on poly might be a good plan.
Old 03-06-2011, 01:36 PM   #6
I would just tint the varnish.
StevenH is offline   Reply With Quote
The Following User Says Thank You to StevenH For This Useful Post:
Ole34 (03-07-2011)
Tags
paint , poly , stain
metal left in hardwood floor sealer deetu Flooring 26 06-16-2012 08:29 AM
applying stain & poly comb. Jo Melchiori Interior Decorating 0 10-05-2010 11:22 AM
Can you use a poly stain on an exterior door that is covered with a porch insfan1 Remodeling 1 09-11-2010 07:56 PM
Stain over Poly? megkatgre Flooring 3 04-27-2010 01:07 PM
can I just stain and poly my old wood floors? hollyworthy Flooring 3 07-23-2008 02:55 PM
