Can I Spray Rust-Oleum Clear Rust Inhibitor Directly Onto Rust? - Painting - DIY Chatroom Home Improvement Forum
Old 05-30-2012, 06:06 PM   #1
Rewards Points: 308
Can I spray Rust-Oleum Clear Rust Inhibitor Directly Onto Rust?
Found an old vintage chandelier on the side of the road that I want to hang out by our pool. It is all rusty from years of being outside, but I like the old patina. I purchased a clear rust inhibitor from Rust-Oleum in order to stop the rusting and to extend the life of the chandelier, but after reading the directions, is says to remove the rust before applying. Should this still work to seal in the current patina or do I need something else?
smokey847 is offline   Reply With Quote
Old 05-30-2012, 06:25 PM   #2
Too Short? Cut it Again!
Why are you posting this again like a week later? You got good answers to your last post in the interior decorating section!
Old 05-30-2012, 06:52 PM   #3
Rewards Points: 308
Because is a specific question I have about the particular product I bought--something painters may know more about than interior decorators.
Old 05-30-2012, 07:38 PM   #4
Ok. To answer your question, the clear coat may inhibit some future surface rust but you should wire brush or steel wool any you can off or use something like Naval Jelly. I would not expect the clear coat to arrest the oxidation already in progress. Your other option is to use a rust conversion paint. It is pricey but you will not need much. Of course you may loose the look you are after. All the converters I know of leave a black surface. There are a bunch of brands. these are two I have used.
Old 05-31-2012, 01:10 AM   #5
Rewards Points: 308
Thanks! I may give the clear coat a try on a part of the chain first to see.
Where to buy anti rust spray for steel chainsnthick? boba7523 General DIY Discussions 11 10-05-2011 12:14 PM
Cleaning brush StevenH Painting 19 02-06-2011 12:13 AM
