Can I Sand Between Top Coats? - Painting - DIY Chatroom Home Improvement Forum
Old 09-15-2009, 12:21 AM   #1
Can I sand between top coats?
I just put on a first top coat and noticed some drips too late. Can I sand them down before putting on the final top coat?
cevamal is offline   Reply With Quote
Old 09-15-2009, 12:26 AM   #2
Haste Makes Waste
A light sanding is always good between coats (app 220 grit)
saggdevil is offline   Reply With Quote
Old 09-15-2009, 03:54 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 152
You will have a hard time sanding freshly applied paint. Take your 5 in 1 and scrape off,patch and re paint.
Old 09-15-2009, 07:01 AM   #4
the Musigician
DangerMouse's Avatar
sand what? paint? oil or latex?
varnish? poly? lacquer? shellac?
how long has it dried? still soft will not sand, just make a big mess.
i've taken a single edged razor and had success at removing drips with no need to repaint.
is it drops on flat surface, or drips/runs on vertical?
DM
Old 09-15-2009, 07:20 AM   #5
Sorry for the lack of details!
It's latex paint. I finished last night at eleven and won't be able to get to a second coat until around eleven this morning, so twelve hours dry time. It's drips on vertical.
The 5-in-1/razor is a great idea, thanks!
Do screw heads really need to be mudded with three coats? KUIPORNG Remodeling 33 09-17-2011 02:54 AM
How many Coats Wiluven Painting 5 01-21-2008 06:50 AM
sealing grout, how many coats? Yeti Flooring 1 10-19-2007 11:23 PM
2 coats versus 3 coats joeyboy Painting 9 08-24-2007 12:43 PM
Be honest, do you really do three coats on everything? KUIPORNG Remodeling 18 03-30-2007 04:02 PM
