Can I Paint On Top Of Old Wallpaper? - Painting - DIY Chatroom Home Improvement Forum
Old 04-25-2011, 03:37 PM   #1
Can I paint on top of old wallpaper?
Our new home was built sometime around the 1950s and some of the rooms have been updated while others have not. The bathroom and entryway both have an older style wallpaper that is very hideous so I've made it a priority to tackle that first. My question is whether it's possible (to get good results) to paint on top of the existing old wallpaper or do I absolutely have to remove it first. Some people say to remove it while others say you can texture on top of it and then paint.
mrominger is offline   Reply With Quote
Old 04-25-2011, 04:32 PM   #2
ltd
Rewards Points: 536
yes you can. glue down any loose seams,oil base prime ,top coat latex. i have done this many times.and it looks ok, kind of like someone painted over wallpaper. my point is you may be in that house for a long time just do it right .striping wall paper not as bad as people make it out to be .the end result is you will have a beautiful room you can be proud of.
ltd is offline   Reply With Quote
Old 04-25-2011, 04:43 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Wow!!!
XXX
Old 04-25-2011, 05:47 PM   #4
Rubbin walls since'79
Brushjockey's Avatar
While it's true you CAN do it, it's not what you should do. You will be sealing in potential problems that can rear their head later, or not later.
Strip to bare wall is always preferable. except if it is permabonded- usually because it has been pasted onto raw sheetrock, then before you destroy the wall it's better to seal in and then paint.
I just had a job where the owner insisted we seal in and skim over to make a smooth wall. Even after sealing with BIN ( pigmented shellac) the paper was loose and needed to be cut out in so many spots it would have been easier to strip and do it right.
Shortcuts don't always pay.
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
jsheridan (04-25-2011)
Old 04-25-2011, 05:52 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
There ya go!
XXX
Old 04-25-2011, 05:53 PM   #6
Brush, do you like BIN for that as opposed to Cover Stain? BIN has a water component. I've always used CS.
Old 04-25-2011, 06:56 PM   #7
NACE Coating Inspector
mustangmike3789's Avatar
yes you can, but i would suggest that you paint it green and let some grass grow up around it so it will be harder to see all of the problems that will create
mustangmike3789 is offline   Reply With Quote
Old 04-25-2011, 07:13 PM   #8
Learning by Doing
Leah Frances's Avatar
It's bad karma to paint over wall paper. Someone else will own your home one day and they will hate you for it.
- signed a girl who curses the former owner of my house on a bi-weekly basis.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 04-25-2011, 07:17 PM   #9
Gymschu's Avatar
Rewards Points: 668
This^^^^^
Old 04-25-2011, 07:22 PM   #10
JS-- On top of needing to seal the paper there was nicotine embedded in the paper.
I actually wished we had used CS, might have worked better. But then I REALLY wished we had stripped it. The Nic would have been gone with the paper.
Old 04-25-2011, 07:24 PM   #11
Brush, I answered my own question. While looking at BIN TDS for cousindan, I came across this
Over Wallcovering B-I-N may be used to prime existing, soundly adhered, non-porous wallcoverings to hide patterns/dark colors prior to painting.
Never saw that application. I guess non-porous means vinyl coated and up, not paper paper.
Old 04-25-2011, 07:31 PM   #12
I looked at a job years ago in a little row home in Philly. The people had vinyl wallpaer that turned brownish gold after about five years. They weren't sure why and wanted me to wash it. I asked them if they were smokers. They were both heavy smokers and had quit the year before they installed the paper. The paper was paid for by the money they saved by quitting, and the idea was to eliminate the signs of being smokers. I told them the nicotine was burning through the paper and there was nothing to be done but seal it and paint or remove it. The paper guy never sealed the nicotine and it migrated up through the paper. The weren't too happy to hear that, and I think, that as the messenger, I got shot. The paper job wasn't all that hot so I figured the guy wasn't either.
Old 04-26-2011, 06:46 AM   #13
paper hanger and painter
chrisn's Avatar
Rewards Points: 312
NO, NO, NO,NO,NO,NOOOOOO!
chrisn is online now   Reply With Quote
Old 04-26-2011, 06:49 AM   #14
chrisn's Avatar
Rewards Points: 312
[quote=jsheridan;636461]I looked at a job years ago in a little row home in Philly. The people had vinyl wallpaer that turned brownish gold after about five years. They weren't sure why and wanted me to wash it. I asked them if they were smokers. They were both heavy smokers and had quit the year before they installed the paper. The paper was paid for by the money they saved by quitting, and the idea was to eliminate the signs of being smokers. I told them the nicotine was burning through the paper and there was nothing to be done but seal it and paint or remove it. The paper guy never sealed the nicotine and it migrated up through the paper. The weren't too happy to hear that, and I think, that as the messenger, I got shot. The paper job wasn't all that hot so I figured the guy wasn't either.[/quote]
Bad paper PERSON ( could easily have been a female)
They should have known better
The Following User Says Thank You to chrisn For This Useful Post:
jsheridan (04-26-2011)
Tags
1950s home , old wallpaper , texturing walls , wallpaper removal
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
Textured paint over plaster skim over wallpaper? DIYchallenged Painting 1 07-18-2010 03:14 AM
Paint peeled off like wallpaper. swampette Painting 6 06-23-2009 06:15 AM
Paint peeling after wallpaper removal Gramps Painting 2 09-15-2008 05:20 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
