Can I Paint Primer - Painting - DIY Chatroom Home Improvement Forum
Old 04-19-2013, 05:48 PM   #1
Rewards Points: 874
Can I Paint Primer
My wife primed a little today but there is a slight line where i guess it was not sanded down all the way(see pic). Can this still be sanded even though already primed? Anything specific I should do. Thanks you!!
Mstrlucky74 is offline   Reply With Quote
Old 04-19-2013, 05:58 PM   #2
Rewards Points: 13,300
Happens eveytime.
Fill the low spots, sand the high places, reprime.
Old 04-19-2013, 06:00 PM   #3
Once spackle is primed there is no sanding. Sanding will only break the surface of the primer which will require re-spackling anyway. Hit it with a skim of spackle now and don't waste your time. But what do I know?
The Following User Says Thank You to jsheridan For This Useful Post:
chrisn (04-20-2013)
Old 04-19-2013, 07:17 PM   #4
Painting Contractor CT
Rewards Points: 77
Post
Can I Paint Primer
Sure you can sand it. Then apply thin layer of compound, sand and prime.
Good Luck!
KD PAINTING is offline   Reply With Quote
How paint primer actually works? konsole Painting 4 11-11-2010 05:48 PM
Oil based paint over Latex? No need for Primer? Jasonuncloned Painting 2 10-20-2010 11:33 PM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 11:00 AM
Primer vs. Flat paint lovetrading Painting 3 08-22-2008 09:13 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-18-2008 12:04 AM
