Can I Paint Over Wood That's Been Stained? - Painting - DIY Chatroom Home Improvement Forum
Old 05-30-2011, 02:12 PM   #1
can I paint over wood that's been stained?
Can I paint over wood that's been stained/
Deborah Grimes is offline   Reply With Quote
Old 05-30-2011, 02:18 PM   #2
I would use a stripper first. That way the product will adhere better to the wood.
Imho, stained wood normally looks better than painted but to each their own.
If you buy Behr paint or something of the like, beware its very hard to get the paint off years down the road and might need a pro to strip it for you.
Katz is offline   Reply With Quote
Old 05-30-2011, 03:31 PM   #3
Too Short? Cut it Again!
Of course you can paint over stained wood. It will probably have a poly or varnish finish on it though so you will need to rough that up with fine grit sandpaper.
And you must be diligent about cleaning kitchen cabinets before trying to paint them. TSP is the paint industry standard. I actually like Purple Power and a clean rinse. You can get it at auto parts stores. I start with low odor mineral spirits first.
I like priming kitchen cabinets with a paint store, not a box store, alkyd primer but you can use a good superbonding waterbased primer too if you plan to finish with latex semi gloss or something which would be my choice these days. You will want two nice finish coats.
Use good tools and add some Floetrol to the paint.
Old 06-04-2011, 04:10 PM   #4
Yes use oil primer, Duration= Happiness
warminwisco is offline   Reply With Quote
Old 06-04-2011, 06:45 PM   #5
You want a slow drying oil primer, one that takes 24 hrs to dry.the fast drying oil primers like kilz, dry so fast they become brittle and dont hold up in the long run. The slower the dry time the more time it has to bond to the surface for a stronger base coat that will resist chipping better down the road.
http://www.davemacpainting.com/
dave mac is offline   Reply With Quote
Old 06-04-2011, 09:07 PM   #6
Solvent (oil) based ALKYD primer not just oil based primer unless you plan to paint an oil finish over it.
And the drying time of a primer has nothing to do with the quality of the film it leaves behind. Solvent bases primers and paints just take longer to evaporate than water based products.
You can get away with a nice, quality, high bond latex primer for this (if you plan to finish with latex).
A nice oil based alkyd will stick to almost everything cleaned and prepped and leave a neutral primer film to which near anything will stick.
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
Cleaning brush StevenH Painting 19 02-06-2011 12:13 AM
Removing latex paint from wood trim ulbass Painting 1 03-12-2009 02:19 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-18-2008 12:04 AM
