Old 07-14-2009, 03:12 PM   #1
CLM
Can I paint over wallpaper primer?
My bathroom was professionally wallpapered about 8 years ago, and now I've removed the wallpaper and want to repaint.
Mercifully, it looks like the initial papering was done well and correctly. It came off easily, and I'm left with this odd white-washed look over the previous pink/green/blue sponge painting.
At first I thought this was wallpaper paste, and tried to scrub it off with enzyme wallpaper stripper and a scouring sponge. I managed to get some off, but it was insanely difficult. With further research, I think it's actually something like Sheildz wallpaper primer. It looks like it was applied with a wide wallpaper brush rather than a roller. Does this sound like a reasonable guess?
Finally, can I paint right over the wallpaper primer (if that's what it is) now that the wallpaper is off? Or do I have to sand? Re-prime? Something else?
Thanks!
CLM is offline   Reply With Quote
Old 07-14-2009, 07:53 PM   #2
paper hanger and painter
chrisn's Avatar
I would make sure as much of the paste is removed as possible,sand smooth, prime with Gardz( which will lock down any residual paste) and paint.
Old 07-14-2009, 09:58 PM   #3
CLM
Ah, that's excellent. I'm soaking the walls in enzyme cleaner, and "shaving" off more paste than I realized they had. I've read about the mess painting over paste can produce, so I'm happy to hear about the Gardz. I'm worried I'll miss some paste and cause myself worse problems later.
Thanks! I'm doing exactly as you say.
Old 07-15-2009, 04:40 AM   #4
chrisn's Avatar
You're welcome, keep using your removal solution( a green "scrubbie" pad used for pots and pans) works well for the last step in conjunction with lots of hot water.
Tags
wallpaper removal
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
oil base paints NoExperience Painting 30 09-04-2008 06:37 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
