Old 08-05-2009, 02:47 PM   #1
Can I paint over Minwax polycrylic
Can I paint over minwax polycrylic with spray paint? Do I need a primer or can I just go over it with spray enamel?
pomelo is offline   Reply With Quote
Old 08-06-2009, 06:13 AM   #2
Matthewt1970's Avatar
I would almost recommend not doing it. It might be just fine seing as how spray oil enamel will stick to just about anything, but you are making a transition from a latex/water based fiish to an oil base.
Old 08-07-2009, 04:07 PM   #3
NAV
Clean, dry and dull.
i would sand a little, prime with S-W PrepRite Bonding Primer and stick with acrylic. after all, they are phasing out alkyd paints. in many states you can only get alkyds for corrosion resistance.
NAV is offline   Reply With Quote
Old 08-10-2009, 03:36 PM   #4
Do they make acrylic or latex spray paint? All the ones I see at Lowes or Home Depot are oil based spray paints.
Old 08-10-2009, 03:50 PM   #5
NAV
they do make acrylic spray paints. spray paint is exempt from most VOC regulations.
Old 08-12-2009, 12:42 AM   #6
Painting Company, NY
housepaintingny's Avatar
Polycrilic is a waterbourne product, you never want to use an oil product over a waterbourne, it causes a lot of problems, but it is ok to use a waterbourne pruct over oil. You should sand the surface first(lightly), clean the surface, prime the surface with a waterbourne product(100% acrylic), then apply your top coat using a waterbourne product, some waterbourne products are not 100% acrylic. Visit us on the web to read about the benefits of 100% acrylics
housepaintingny is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
