Can I Paint My MDF Treads? - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-19-2007, 12:52 AM   #16
Pro Painter
There is some tolerance on stair height and depth. You could tack 3/8 or 1/4 luan to the risers and depending on height could probably do the same with the treads. Cover seams with trim. This would pass inspection unless the rise is already at the maximum height. But all the trouble of doing it would outweigh buying oak (or any other wood) stock and cutting your own treads. This would also allow the new riser wood to go below the tread depth. I think.
Where's atlanticwb? He would know for sure.
As long as the houses' price was inline with what they did, the new oak would raise the value of the home.
joewho is offline   Reply With Quote
Old 07-27-2007, 01:09 PM   #17
Rewards Points: 150
I was thinking about doing the same in my house.
In the end, could you just cut out the MDF tread then then put in an oak, bullnosed tread (sold and precut at a box store) stain and be done?
Do you think there will be an issue when the MDF get's cut out?
dcd22 is offline   Reply With Quote
Vinyl Paint - PolymatrX - and Siding.... Classic Painting 2 07-23-2008 07:45 AM
SW Duration paint - OK to thin with water? plin321 Painting 10 08-11-2007 10:29 PM
Paint coming off of siding ciera Painting 5 07-01-2007 06:22 PM
exterior paint question sherlock Painting 5 07-05-2006 08:31 AM
