Old 03-23-2010, 09:12 PM   #1
Can I paint fascia after gutters are installed?
I'm not sure I want to paint the fascia, which is currently untreated cedar. What kind of issues should I expect if I change my mind after the gutters are installed?
echase is offline   Reply With Quote
Old 03-23-2010, 09:46 PM   #2
That's no problem. Generally you just paint the part below the gutter that you can see, the backside to where it meets the soffit and the return. That is not an uncommon thing to do.
Windows is offline   Reply With Quote
Old 03-24-2010, 10:44 AM   #3
Cool, thanks for the reply. I was concerned that having it only painted below the gutter may not allow any moisture that makes it into the wood to get out, but I tend to over-think these things.
Theory is rarely a good substitute for real-world experience.
Old 03-24-2010, 12:27 PM   #4
In my experience the way they install gutters - up tight at the top of the fascia with an over lap from the shingles - really protects the upper part of the fascia from the weather.
Old 03-24-2010, 07:36 PM   #5
water flows downhill
oarfish's Avatar
Use stain on rough cedar if you don't have too many carpenter bees around. Otherwise better prime with shellac and paint with SW Duration
oarfish is offline   Reply With Quote
Old 03-24-2010, 08:22 PM   #6
Carpenter bees aren't too heavy here, and I love the rough cedar, unstained. We MIGHT go with white fascia and trim, leaving the siding natural.
Old 03-25-2010, 05:21 AM   #7
paper hanger and painter
chrisn's Avatar
When installed PROPERLY, this is true
Old 03-25-2010, 10:02 AM   #8
I'll have gutter apron, so the fascia should be pretty well-protected.
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
latex paint on top of oil-based paint nancy-diy Painting 11 03-07-2010 04:02 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 01:50 PM
