#1 |
HGTV Junkie
Can I mix semi-gloss with eggshell?
Hi everyone. I purchased latex semi-gloss paint for the kitchen walls and I'm having second thoughts about the gloss. I would have rather purchased a satin finish. Can I mix the semi-gloss paint with eggshell paint to tone down the gloss? I would appreciate any suggestions.
#2 |
Do it. I have done it on occasion.
But mix it very well first. |
#3 |
HGTV Junkie
Is the result when you mix it similar to satin finish? How much of the gloss is diminished?
#4 |
Tired, Cold, and Damp
It splits the difference
It should be similar to some companies "satin" (there is no standard from company to company) It should do want you want |
#5 |
HGTV Junkie
Thank you so much for the input.
#6 |
Can I mix semi-gloss with eggshell? |
#7 |
I agree with Slickshift. As long as you stay within the same Brand and Line of paints, you shouldn't have any problems. Once you start mixing lines of paints from the same Brand (like Sherwin Williams SuperPaint with Sherwin Williams Everclean), or different Brands of paint, you can run into incompatability problems between the coalescing solvents and additives in each brand. Normally the result of such incompatability problems is a non-uniform gloss called "flashing".
Maybe just buy a quart of eggshell and mix it in different ratios with the semi-gloss to find the satin gloss you like best. Obviously, the amount of each colourant added to a quart will be 1/4 of that used for a gallon to mix the quart to the same colour as you have.
Bashing my head against the walls in some of the internet's finest chat rooms. |
| Display Modes | |
| semi gloss enamel vs eggshell enamel | NoExperience | Painting | 18 | 03-05-2009 05:57 AM |
| Semi gloss on Semi gloss | mattpricemn | Painting | 6 | 08-25-2008 08:18 PM |
| Semi gloss on Semi gloss | mattpricemn | Plumbing | 1 | 08-24-2008 04:19 PM |
| semi gloss sheen problems | Pawl | Painting | 5 | 03-15-2008 11:29 PM |
| Cabinet Painting: Gloss vs. Semi Gloss | digexpressions | Painting | 1 | 12-29-2007 04:47 PM |
