Can I Latex Paint Over Fresh Oil Stain - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-30-2011, 12:26 PM   #16
Ironlight's Avatar
I personally would not give up on the stain yet. Put on a few more coats, let it sit. The lighter areas may darken enough to a point that is closer to what you were looking for.
If I was going to cover it with paint I would wait close to a week before I even thought about priming it. You want it dry as it's going to get before you cover it.
Ironlight is offline   Reply With Quote
Old 11-30-2011, 04:11 PM   #17
paper hanger and painter
chrisn's Avatar
Rewards Points: 614
Originally Posted by LidoGirl View Post
thanks Mazey, I actually took the runner off the stairs because it was hard to keep clean and the wood treads looked so beat up. I might have to consider adding it back if the paint doesnt hold up. either that or down the road maybe pay to have nice oak treads put in. For now I want to see what I can do with paint since stain wont work.
jsheriden- That is what I was thinking, I have oil based zinsser cover stain from a previous project, then a porch and floor paint (was thinking behr but if theres something better I'm for it) and then two coats of water based poly. Everyone seems to be saying different things.
so confused!
just about ANYTHING would be a step up
Old 11-30-2011, 05:41 PM   #18
Originally Posted by Brushjockey View Post
This isn't so much DIY- but I do make my own tinted varnish often- either by adding regular tint or a bit of stain into it (oils).
Since you used such a dark stain to begin with, I think the hardest thing will be reducing that back. But because you preconditioned- that will help .
I suggest you work on one stair- see how far back you can take it, and then post a couple of pics.
That is if you don't go the paint route. I stand corrected ( again! dang!) about using the floor paint. I often paint the risers and skirts and have the steps themselves be a varnished finish. (Another thing to consider).
"The whole world is watching".
Just teasin. We all have our moment in the chair. Honestly, I sensed that was an oversight on your part, that's why I put the lol behind the "memo" line. I learned a long time ago that gloating creates negative karma.
Old 11-30-2011, 05:46 PM   #19
I had a conversation today in HD with the Behr rep. I asked how they fortified their floor enamel, they're epoxy fortified, no urethane. For what that's worth. Ric may know better, but I think urethane would be superior to epoxy. I worded that with Brushjockey's shadow in mind, lol.
Old 12-01-2011, 03:47 AM   #20
chrisn's Avatar
Rewards Points: 614
The prof's lecture is being written
The Following User Says Thank You to chrisn For This Useful Post:
jsheridan (12-01-2011)
Old 12-01-2011, 08:45 AM   #21
how DO you get stain off if I should decide to start over from scratch? belt sander? stripper?
LidoGirl is offline   Reply With Quote
Old 12-01-2011, 09:31 AM   #22
Rubbin walls since'79
Brushjockey's Avatar
I think Ric mentioned in his first reply- Use a rag with mineral spirits- might follow up with a scrubbie once it softens up. This will not take it totally off, but might lighten it enough that you can seal and then overcoat with a tinted varnish to even it out.
This is not DIY 101, but we all learned by doing stuff like this.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 12-01-2011, 12:49 PM   #23
I tried to attach pics. The main problem is the contrast between grain and no grain areas. Not sure if tinted varnish will help. I also found out that you can't buy oil paint in CT so I'd have to get the latex epoxy reinforced floor paint. (sigh) what a mess.
Old 12-01-2011, 01:07 PM   #24
Lido, what is wrong with those steps? I think they look great. That's fabulous grain and a great accent of it. It almost looks to me like the stair maker laid them out purposely. Me, I would poly over them and enjoy them, but that's me.
Joe
Old 12-01-2011, 01:20 PM   #25
I agree with Joe- that is how that wood looks. And it looks fine.
I think if you put a satin sheen- not a gloss- it will mellow it a bit. If you want to add just a little of your stain in the finish, ( not so much that you are graining with the brush) it will soften the look a bit also. But if the color overall is acceptable to you, I'd go with it.
Old 12-01-2011, 03:26 PM   #26
The contrast is too much, they are too rustic looking for me. I wanted a more contemporary look. The pictures don't look as bad as they do in person either, there's a lot of splotches and stains that showed up that I expected the dark color to hide. Thanks for all the advice, i wish I liked them as much as you guys do .
Old 12-01-2011, 04:57 PM   #27
Matthewt1970's Avatar
Rewards Points: 1,098
When we did we start recommending standard trim enamel on a surface to be walked on? Did I miss a memo? lol I suggest a porch and floor enamel.
This. And even the floor enamel in OIL will eventually chip. If it were me I would opt for a 2 part epoxy and NOT the water based version. Now you have to wory about traction. Have you considered carpet?
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 12-01-2011, 05:18 PM   #28
Ironlight's Avatar
More coats! Let it sit! Seriously, that will reduce the contrast because the darker areas will not get much darker while the lighter parts will. At the very least try a few more coats on one step to see if it improves it more to your liking.
And the poly on top of it will darken it and decrease the contrast a bit as well. Tinting the poly will help further in that respect.
As for removing it, you'd need to sand it out. Stain penetrates the wood. You need to remove the stained wood, essentially.
Old 12-01-2011, 05:37 PM   #29
Matt, BM latex floor enamel is expoy fortified, I doubt if it would chip with a good bonding primer under it.
Old 12-01-2011, 05:57 PM   #30
If you don't mind it being overall darker- I think tinted varnish is your best bet for getting a subtler contrast.
cheap paint in bathroom got mold? mayhem69 Painting 12 05-06-2012 04:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
Fresh acrylic primer + paint not sticking paul_l Painting 12 09-23-2010 09:06 AM
latex paint on top of oil-based paint nancy-diy Painting 11 03-07-2010 03:02 AM
painting Navagator Painting 6 10-12-2008 11:14 PM
