Old 09-20-2006, 08:35 AM   #1
Can I get away with only painting plasterboard walls???
I have just bought a block home & the paint seems to be fine apart from the plasterboard walls, they have patched up holes n not painted over it.
Is there any way I could make a theme or something??? I don't want to have to spend alot of money painting the whole house again.....
JoJo is offline   Reply With Quote
Old 09-20-2006, 09:01 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
In my opinion, they would look bad unless painted
slickshift is offline   Reply With Quote
Old 09-24-2006, 08:54 PM   #3
Painting Contractor
If you could paint it yourself, you would'nt have to spend more than the paint and supplies (probably no more than $800).You just bought the house, did you set aside money for improvements and repairs after the move in?
Paintguy26 is offline   Reply With Quote
Old 09-24-2006, 09:33 PM   #4
Can you just get paint to match and "touch-up" the patched spots for now?
And then maybe down the road paint the whole area when more money is available?
redline is offline   Reply With Quote
Refinshing floors before painting walls? ponchoman1 Flooring 6 03-14-2009 05:21 PM
Painting walls different color at an outside corner J187 Painting 8 08-16-2006 08:16 PM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 06:33 PM
painting walls w/oak trim THEBIGPUNN Painting 3 04-25-2006 03:28 PM
painting 18' walls sedona48 Painting 1 02-07-2004 07:18 PM
