Can I Apply Polycrylic Over Polyurethane - Painting - DIY Chatroom Home Improvement Forum
Old 07-02-2015, 05:44 PM   #1
Rewards Points: 8
can I apply polycrylic over polyurethane
I applied a coat of Minwax fast drying polyurethane on a bookshelf for my daughter's bedroom. I didn't realize it was oil based until I was finished. I am concerned about the odor and would like to finish the bookshelf with a water based polycrylic. I have asked someone at Lowes and called Minwax and checked the Minwax website, getting different answers each time. Does anyone have any experience with going over a polyurethane with a polycrylic?
Lkreeser is offline   Reply With Quote
Old 07-02-2015, 07:25 PM   #2
DIY staff
Rewards Points: 7,174
I use both frequently----
I have never tried to top coat oil based with water based and would be very concerned about it bonding---the oil poly takes a week or two to fullly cure--until it is completely cured--trying to use the water based would be a huge risk.
If it were my project, I would finish it with the oil based and wait until the finish is cured if you find the odor to be offensive.
The Following 3 Users Say Thank You to oh'mike For This Useful Post:
Gymschu (07-02-2015), joecaption (07-02-2015), ToolSeeker (07-04-2015)
Old 07-02-2015, 10:58 PM   #3
Rewards Points: 2,906
I agree with Oh'Mike. Now that you've started with an oil based coating, you're running the risk of creating new problems for yourself by switching to a water based coating. Sticking with the oil based is a safer bet.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Old 07-03-2015, 08:28 AM   #4
Rewards Points: 8
Thanks for your reply. When I called Minwax, the person I spoke with told me it would be okay to overcoat with polycrylic, but I was not convinced. Do you think it would be okay if I waited for 30 days for it to fully cure and then sanded the book case and then covered it with polycrylic? How about using the oil-enhanced water based poly instead? I keep thinking about toxic fumes in my daughter's bedroom.
Old 07-04-2015, 08:02 AM   #5
Rewards Points: 5,974
What toxic fumes? Oil based poly is not toxic. it just has a strong odor that dissipates over a little time. If it really bothers you that much sand it down and start over.
Entering your general location can help with answering a lot of times
Old 07-04-2015, 09:01 AM   #6
Rewards Points: 8
Sorry, but I am confused. I thought the fumes from the oil based poly were bad for you since I have read that children and pregnant women should avoid them. Are you saying I should not be worried about using it on my daughters furniture?
Old 07-04-2015, 09:37 AM   #7
Gymschu's Avatar
Rewards Points: 240
The fumes are strong with oil-based poly. I agree with everyone else that you should just finish up with the oil-based. Poly is such a hard finish that even if you sand it down, clean it, etc. I think the possibility is high that you will have adhesion problems with the water-based on top of it.
If you can take the bookshelf to a garage or workshop area that would be the best way to finish off the project. Then your daughter won't be subject to the strong fumes.
Giving us your general location helps us better help you!
Gymschu is online now   Reply With Quote
The Following User Says Thank You to Gymschu For This Useful Post:
oh'mike (07-04-2015)
Old 07-04-2015, 12:26 PM   #8
Jmayspaint's Avatar
Rewards Points: 534
It's only dangerous during the drying/curing process. As long as you used an interior use product, once it's cured it's done off-gassing. The dried film itself isn't dangerous, only the solvents used and they evaporate over time.
Jmayspaint is online now   Reply With Quote
Old 07-05-2015, 12:01 AM   #9
Rewards Points: 8
Thanks for your help. I will just finish it with oil based poly and leave it out of her room until it has cured.
The Following 2 Users Say Thank You to Lkreeser For This Useful Post:
Gymschu (07-05-2015), oh'mike (07-13-2015)
Old 07-13-2015, 01:01 PM   #10
Rewards Points: 386
I wouldn't suggest it
harpua728 is offline   Reply With Quote
Maximum time to apply next coat Homerepairguy Painting 8 09-26-2014 03:49 AM
Minwax Polycrylic vs Minwax Polyurethane sukhenkoi Remodeling 3 06-17-2013 02:48 PM
can I apply polyurethane of arcylic craft paint rcovey Painting 2 09-26-2012 05:04 AM
Best way to apply polyurethane on new oak floors blk94f150 Flooring 0 05-12-2010 09:18 AM
oil vs water poly batwoman Flooring 6 09-30-2008 11:00 PM
