Can Anyone Help Match Textures - Painting - DIY Chatroom Home Improvement Forum
Old 07-08-2008, 12:14 PM   #1
Can anyone help match textures
Trying to match texture after major wall repair. Can't seem to find the right technique. Any advice? Does anyone know of a web site where there are pictures of all textures with 'how to' info attached?
Sasha2000 is offline   Reply With Quote
Old 07-08-2008, 05:00 PM   #2
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 918
Might be able to match that with a roller and 3/4" nap and some thinned down joint compound.(not thinned out to much at all).
Sir MixAlot is offline   Reply With Quote
Old 07-08-2008, 07:24 PM   #3
THANK YOU! Would that be a regular roller you'd use for paint?
Old 07-08-2008, 07:41 PM   #4
Rewards Points: 918
Yes. just make sure it is a 3/4" nap. Get a paint grid for a 5 gallon bucket and put about a 1/3 of a bucket of joint compound with about a 1/4 cup of water. Then mix. You will have to fine tune your technique and possibly your texture mix. Let us know how it works out for you or if you have any other questions. Good Luck!!
Old 07-10-2008, 04:22 PM   #5
Very close match. Played with it for about 15 min and got it very close. I will do some knockdown when it is dry to simulate 50 years of paint and then apply a very heavy coat.
Old 07-10-2008, 08:40 PM   #6
Rewards Points: 918
I knew you could do it .
That's Great!!
Quarter Round for hardwoods - White or match the floor? mr_ekco Flooring 6 02-22-2011 06:00 PM
Who can mix paint to match home color exactly? darsunt Painting 20 06-20-2009 11:46 PM
Paint to match Crema Marfil Marble Misslpc1 Interior Decorating 4 03-16-2009 09:54 PM
matching textures in 1953 house Sasha2000 Painting 3 07-05-2008 12:16 PM
French Doors That don't Match! terryb Building & Construction 21 12-17-2007 07:19 PM
