Cabinet Paint Still Tacky After A Week.... - Painting - DIY Chatroom Home Improvement Forum
Old 09-04-2009, 03:14 PM   #1
Rewards Points: 79
Cabinet paint still tacky after a week....
Last weekend, I painted some trim and cabinet doors with Ace Cabinet, Door, and Trim paint. The trim is white over factory primer and two coats of the Behr premium plus ultra with primer in it. It has finished beautifully, to a nice hard shine and is exactly what I wanted. (Whereas the Behr... wasn't...)
The black, is on the generic HD oak cabinet doors that were unfinished, then also had 2 coats of the Behr on them. They're still tacky and "damp" at this point (get a little color off of them by touch). I'm guessing maybe I put it on too thick, but am unsure what my options are to "fix" it. Presumably, it would have set by now if it was going to. Do I need to sand? Repaint? Reprime?
Any help appreciated.
Mike
tigereye is offline   Reply With Quote
Old 09-04-2009, 03:25 PM   #2
the Musigician
DangerMouse's Avatar
were the oak doors truly 'raw' or did they maybe already have an oil finish on them?
if not, then the behr paint is the likely culprit....
did you remember to primer them?
if so, then the behr paint is the likely culprit....
DM
Old 09-04-2009, 03:36 PM   #3
Rewards Points: 79
DM
The doors were raw (and rough for that matter). Just bought them a couple of weeks ago. The Behr was their "all in one" product with primer in it. It's what my Dad told me to get when I first started to talk about painting the cabinets... note to self... research first... don't listen to dad about paint...
I figure that sanding them down at this point would probably make a mess if the paint hasn't cured, but not sure if there's better solution.
Old 09-04-2009, 04:27 PM   #4
100 Year Family Tradition
4ThGeneration's Avatar
Did you use an paint additive in the paint before you coated the cabinets?
After it completely dries you need to sand down, making sure none of the coatings you applied are going to peel off. You can actually strip off the failed coating which is what I would do just to be safe that in a few months you do not have problems.
Glyptex is a great choice for coating cabinets. The main idea is always dull/Clean/Dry before you coat. Never fall for the all in one coatings. Always use a undercoater that will grip the surface and allow the top coats to bond.
4ThGeneration is offline   Reply With Quote
Old 09-04-2009, 06:52 PM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
You got that right.As you said if it is not completely cured( 30 days for normal latex, Behr with primer? who knows) you will never be able to sand it. I would probably get some stripper( paint) and start from scratch with REAL primer and paint, that means avoiding Bloes and Homely Depot altogether.
Old 09-04-2009, 07:08 PM   #6
the Musigician
what he said
DM
Old 09-04-2009, 11:50 PM   #7
Matthewt1970's Avatar
Rewards Points: 1,098
If you could successfully mix primer and paint together, then they would have been doing it decades ago. The stuff you need to have in primer to make it primer really leaves no room left for the stuff you need to make it paint. If you mix it 50/50, then the bonding, sealing, stainblocking and penetrating power of the primer is cut in half as well as the finish quality of the paint is also cut in half.
Old 09-05-2009, 05:29 AM   #8
chrisn's Avatar
Rewards Points: 228
Makes sense to me
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 11:00 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
