CAB Acrylic Lacquer - PROBLEMS - Painting - DIY Chatroom Home Improvement Forum
Old 10-19-2010, 04:56 PM   #1
Hi,
I am at my wit's end and any help would be greatly appreciated!! I built a cabinet out of birch plywood and sprayed it with a CAB Acrylic Lacquer but not before priming it with the required primer/sealer. I've put on several coats now and it has these random "dry" spots. A buddy of mine said it looked like the overspray was actually drying before it hit the piece and that was causing the dry areas. I'm spraying with the recommended nozzle (1.4 mm) and don't see where I'm doing anything else wrong. What can I do??
Thanks in advance!!!
ToneyTech is offline   Reply With Quote
Old 10-20-2010, 06:18 AM   #2
What type of reducer are you using? Do you live in a humid area?
mark942 is offline   Reply With Quote
Old 10-20-2010, 08:30 AM   #3
Thanks for responding
I'm actually not using a reducer because the product sheet basically said it was thin enough to spray with a 1.4mm tip at %0 reduction. I do live in a VERY humid area (Coastal SC). BTW, I am spraying this with an HVLP. Don't know if that makes a difference.
Thanks.
Old 10-20-2010, 03:20 PM   #4
it can, water can cause what you described but the biggest cause is some type of wax or grime in the wood that's preventing it from laying flat. i haven't shot this stuff in awhile but remember it behaving similar to car paint. think i used acetone to cut it. if you're already getting a good fog with a 1.4mm tip that's pretty thin already though. anyway, dry spots are usually grime, like i said, or poor lighting and you not getting even application.
racebum is offline   Reply With Quote
Old 10-21-2010, 06:34 AM   #5
Your buddy might be right. Try using a little reducer for a quicker flash time. Also as commented, over lap your spray pattern 1/4. HVLP is the best way to go IMO.
Oil- Acrylic Primer- Oil? blue_fox Painting 3 06-23-2010 11:32 PM
Multiple problems in 3 year old house I just purchased swenard Plumbing 12 08-31-2009 03:53 PM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 09:18 AM
Elec short causing A/C problems or A/C problems causing elec problems? Marlon Electrical 2 06-25-2008 02:04 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
