A/C Question About Paintint Trim - Painting - DIY Chatroom Home Improvement Forum
Old 08-24-2007, 04:50 PM   #1
A/C question about paintint trim
If I'm painting interior trim with oil based paint and I want it to dry as fast as possible, is it better to turn the A/C off and let the house heat up or run the A/C and keep the humidity down? Assume 95 degrees ambient outdoor temperature and 80% relative humidity.
BTW.... I'm a chemical engineer and I think about piddly little crap like this all day long.
Thanks,
Marty in Longview, TX
martyshel is offline   Reply With Quote
Old 08-24-2007, 07:50 PM   #2
made in U.S.A.
Hamilton's Avatar
The fastest and easiest way I've found to dry paint around here is to simply open windows and have fans blowing in the rooms.
If you want to speed up the dry time with oil base paint, next time add Japan Dryer - Home Depot sells it.
People sleep peacefully at night because rough men stand guard to deal with violence on their behalf.
Hamilton is offline   Reply With Quote
Old 08-24-2007, 11:26 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
Mmm...not good for painting
Go with the a/c for lowering the humidity rather than the heat w/high humidity
slickshift is offline   Reply With Quote
Old 08-24-2007, 11:30 PM   #4
Pro Painter
I've run into the same question. When possible, I turn on the ac, but leave windows cracked.
joewho is offline   Reply With Quote
Old 08-25-2007, 05:44 PM   #5
Workaholic's Avatar
Rewards Points: 268
I agree turn on the AC and set up some fans.
Sean
Workaholic is offline   Reply With Quote
Standing Seam Roof - Trim Question jpleasants2 Roofing/Siding 4 02-23-2009 11:43 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
First course and trim question Crackers Roofing/Siding 1 08-16-2007 10:21 PM
Shut off valve trim ring question Jeekinz Plumbing 13 04-11-2007 11:44 AM
oak trim, caulking and paint question THEBIGPUNN Painting 2 06-05-2006 09:28 PM
