Buying Paint - Painting - DIY Chatroom Home Improvement Forum
Old 10-12-2011, 06:10 PM   #1
Buying paint
Is there some sort of formula to use to calculate how much paint to need to buy.
Chavez2049 is offline   Reply With Quote
Old 10-12-2011, 07:37 PM   #2
Square footage x number of intended coats of paint is a pretty good place to start. Give that information to the people at your paint store, along with the wall finish (not HD or Lowes) and they will tell you how much you need. Or you can find the information on the side of the can.
That's just my opinion. But it's free, so take it for what it's worth to you.
1910NE is offline   Reply With Quote
The Following User Says Thank You to 1910NE For This Useful Post:
Gymschu (10-12-2011)
Old 10-12-2011, 07:44 PM   #3
Gymschu's Avatar
Rewards Points: 932
Most paints will say anywhere from 200 - 400 sq. ft. per gallon. If you have nice smooth drywall that has been previously painted, you would be closer to 300 - 400 sq. ft per gallon. If it's freshly primed drywall, you may get less per gallon. Also, substrates like concrete block, stucco, and textured walls/ceilings have coverages of about 200 sq. ft per gallon and sometimes less depending on HOW rough they are.
Old 10-12-2011, 09:01 PM   #4
It a newly constructed home and had the basic white finish I'm guessing that's the primer base. Expecting the walls to suck up the paint like a sponge.
Old 10-13-2011, 03:38 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 488
If it is the RIGHT primer and not some cheap crap, that will not happen. Quality primes seal the wall so the paint will stick and not be absorbed.
Old 10-13-2011, 07:30 AM   #6
Chavez, welcome. What you have now is the builder's flat, and it will probably be very absorptive. They're sometimes so that two coats of quality finish will not sufficiently seal the surface, and will leave a lackluster color and sheen, and possibly give problems with uniformity of the finish. I always recommend a full prime over builder's flat to seal the surface prior to finish. This knowledge was learned the hard way.
Old 10-13-2011, 11:48 AM   #7
It's Sherman Williams paint this is where we were told to go get the free touch-up kit. So I'm hoping it shouldn't absorb the paint that much. Should I still prime the walls before I paint?? Thanks for all the insight.
Old 10-13-2011, 05:21 PM   #8
Faron79's Avatar
Rewards Points: 260
Doesn't really matter what brand your existing paint is....cheap builder's-flats exist in all companies! Some builders/painters even dilute THAT a little!!
So, in some ways, you're gonna be painting over quicksand!
As the others have said...RE-PRIME for the best result of your hard work. ESPECIALLY in this scenario!
If you re-prime, I'd aim for ~350sf/gal. with mid-to-top-line paints.
If you stay in the "low-end" range, don't expect much, if at all....over 300sf/gal. for a viable coat anyway!!
Do you know the exact SW paint-series your gonna be using?
Faron
Faron79 is offline   Reply With Quote
Cleaning brush StevenH Painting 19 02-05-2011 11:13 PM
latex paint on top of oil-based paint nancy-diy Painting 11 03-07-2010 03:02 AM
So many questions where to start?!?!(NEWBIE) painter84 Painting 5 09-15-2008 12:50 PM
Paint will not stick in Bathroom! SGTHetland Painting 9 08-17-2008 11:04 PM
