Bullseye 1-2-3 Or Cover Stain For Bare Interior Wood? - Painting - DIY Chatroom Home Improvement Forum
Old 07-08-2009, 01:41 AM   #1
Rewards Points: 16
Bullseye 1-2-3 or Cover Stain for bare interior wood?
I'm going to be spray priming some FJ trim, MDF window sills, and pre-primed Masonite doors here in the next week or so in my new basement. In the past I've always used an oil-based primer like ICI Stain Jammer or Zinsser Cover Stain on bare wood, but I'm considering using the 1-2-3 because I could go ahead and use it on my new drywall at the same time. What do you guys think about the water-based product on the trim? Should I be concerned about the grain raising? Other things to look out for?
The odor and cleanup of the oil products doesn't bother me, and I recycle enough that the environment can take the hit this one time. I'm mostly looking at saving some time if there aren't any disadvantages. Let me hear your opinions. Thanks.
cej22 is offline   Reply With Quote
Old 07-08-2009, 05:17 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 236
For me cover stain would be way over kill for drywall, I would go with the 123.
chrisn is online now   Reply With Quote
Old 07-08-2009, 08:12 AM   #3
Matthewt1970's Avatar
Rewards Points: 1,098
Chris must not have had his cup of coffee yet. He was asking about the trim. Go with the Coverstain. Latex is worthless for wood bleed and will lift the grain of the wood.
Old 07-08-2009, 08:57 AM   #4
I agree with Matthew. You will end up with a better finish and no chance of bleed.
waynech is offline   Reply With Quote
Old 07-08-2009, 04:27 PM   #5
Rewards Points: 16
I'll keep it old school with the oil products. Thanks.
Old 07-09-2009, 04:09 AM   #6
chrisn's Avatar
Rewards Points: 236
I would agree about the trim( I would still use 123 and sand it as it will contain MOST wood bleed) but the new drywall?
Minwax stain does not cover Minwax putty completely proofer Painting 18 11-17-2011 11:40 AM
Washer agitator/spinner turns one way, but not the other IckesTheSane Appliances 5 01-10-2009 03:53 AM
Carpet colorizer to cover up bleach stain? Shpigford Flooring 3 06-30-2008 03:43 PM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 08:34 PM
