Old 12-26-2009, 10:08 PM   #1
Bubbling Plaster?
Howdy:
I had some damaged plaster (over cement) along one wall at baseboard level, several smallish spots. Prepping to paint, I scraped the areas, did a rough sand, then plaster over the areas.
Day two, the plaster dried and I sanded ready for another coat.
Day three: some of the plastered area had bubbled out from the wall. Other were fine.
There are no water pipes in the wall. Is the issue the concrete or maybe the plaster? Why would the plaster bubble out?
Any help appreciated.
Cheers!
szstevo is offline   Reply With Quote
Old 12-29-2009, 04:06 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Bubbling Plaster?
Most plaster needs weeks/months to cure before painting
More info is needed to identify your problem
slickshift is offline   Reply With Quote
Old 12-31-2009, 10:30 AM   #3
NAV
Bubbling Plaster?
sounds like the wall is letting in water. is it below grade or an exterior wall?
NAV is offline   Reply With Quote
Tags
bubbles, plaster
Venetian Plaster FYI Plaster Ayn Painting 10 07-01-2010 12:26 AM
Right materials to patch plaster on masonry? jimhome Remodeling 3 06-08-2009 12:23 PM
Patching plaster in bathroom foothill Remodeling 2 06-02-2009 01:50 AM
Plaster Walls - Did I screw up? jamiedolan Building & Construction 5 11-07-2008 01:10 PM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 06:27 AM
