Bubbles - Painting - DIY Chatroom Home Improvement Forum
Old 11-11-2006, 11:12 PM   #1
Bubbles
I am trying to paint a stairwell into my basement - most of it is fine, but there are a couple of areas that continue to bubble up. Any ideas why that happends, and how to prevent them?
I don't believe there was ever wallpaper on the walls either...
Kyle is offline   Reply With Quote
Old 11-12-2006, 11:57 AM   #2
Darylh's Avatar
Sounds to me like you got some kind of chemical agent (grease, etc etc). Did you clean the wall and WELL rince before painting?
Darylh is offline   Reply With Quote
Old 11-12-2006, 01:35 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
Need more info
What was the surface painted, condition, prep steps taken (if any), what product was used to paint, how big are the bubbles...etc...
slickshift is offline   Reply With Quote
Old 11-12-2006, 08:00 PM   #4
The surface appeared to be clean, but the wall was not rinsed or washed. General prep work was done to smooth the walls, but for the most part, the paint was applied directly on the old paint. A small patch of primer was put over the areas that continue to bubble up - I am not sure if that will work ....
Old 11-12-2006, 10:23 PM   #5
slickshift's Avatar
It's possible, but unlikely the primer will hold
(though certain primers might do it)
Most likely the walls had something on them
Dust, grease, Pledge, dust from the drywall repair...
Means the paint isn't adhering
The solution would normally be to scrape off anything loose, or close to loose, sand, clean, prime, then repaint
After priming a skim coat of joint compound may be needed to smooth out the area
This must then be sanded, wiped clean, and the repair primed again before repainting
Excess moisture could also lift paint
Not sure if that's a possibility in this case
You'd have to check that out
Air bubbles in toilet thisperson Plumbing 4 12-04-2006 06:44 PM
bubbles farrington135 Painting 4 10-14-2006 07:38 PM
