Bubbles - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree13Likes
Old 01-10-2017, 10:00 PM   #16
Gymschu's Avatar
Rewards Points: 178
Re: Bubbles
To add, it is possible that there was some sort of contaminant on the door before it was painted and the heat factor is just exposing that problem. We all can relate to the fact that factory-applied primers on doors like that are notorious for their poor quality. That could have been part of the problem here as well.
Remember too, that the sun (as mentioned before) only hits a small part of that door as it passes overhead. I mean, the UV rays and the accompanying heat may only hit directly on that part of the door for, what, maybe 10-20 minutes a day? Over time that would be enough, IMO, to bubble up the paint much like a magnifying glass used to burn up insects like we did when we were kids.........
Giving us your general location helps us better help you!
Old 01-10-2017, 10:32 PM   #17
Rewards Points: 626
Re: Bubbles
From SW website:
https://www.sherwin-williams.com/hom...DIR-BLISTERING
wptski is offline   Reply With Quote
Old 01-11-2017, 06:42 AM   #18
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 826
Re: Bubbles
Originally Posted by wptski View Post
So from your link to SW, here are what they list.
POSSIBLE CAUSE
  • Heat blistering caused by painting in direct sunlight on a surface that is too warm.
  • Moisture blistering can be caused by the migration of water through an interior wall to the exterior, thus pushing the paint off of the surface.
  • Application of oil-based or alkyd paint over a damp or wet surface.
  • Exposure of latex paint film to dew, high humidity, moisture, or rain shortly after paint has dried, especially if there was inadequate surface preparation and/or poor ventilation in areas such as kitchens and bathrooms.
  • Damp basements.
  • Moisture seeping into the home through the exterior walls.
  • Insufficient surface preparation, painting over a contaminant that the coating cannot adhere to.
Seems like the items in bold are the only real options here as mentioned previously.
Even it was was improperly prepped, the heat would surely exacerbate that and foster the failure.
Gymschu likes this.
Old 01-11-2017, 08:50 AM   #19
Rewards Points: 626
Re: Bubbles
POSSIBLE CAUSE
  • Damp basements.
Up to Post #16, the only thing previously mentioned was heat and that alone doesn't make a bubble.
Old 01-11-2017, 09:07 AM   #20
Rewards Points: 690
Re: Bubbles
A drop of water on the glass will act as a magnifying glass, if direct sunshine hits it before it evaporates.
This redirected sunlight will concentrate on the paint and sure will blister it, before it burns through it.
ED
Windows on Wash likes this.
de-nagorg is offline   Reply With Quote
Old 01-11-2017, 10:47 AM   #21
Rewards Points: 626
Re: Bubbles
ED
Do you get blisters on your skin while sweating in sunlight?
Old 01-11-2017, 11:21 AM   #22
Rewards Points: 690
Re: Bubbles
Totally different scenario.
And I will not dive into this COW-PIE with you.
ED
Old 01-11-2017, 11:26 AM   #23
Rewards Points: 626
Re: Bubbles
ED
Nope! Water refracts sunlight.
Old 01-11-2017, 11:38 AM   #24
Rewards Points: 1,179
Re: Bubbles
The Sherwin-Williams page only mentions excessive heat during application. But excessive heat at a later date will also make paint blister. Ever strip paint with a heat gun? And some paints are more resistant to heat than others. Ever hear of engine paint? I'm just going to sand it down and try a different product with plenty of dry time between coats. Apparently Resilience is not so resilient.
mathmonger is offline   Reply With Quote
Old 01-11-2017, 11:59 AM   #25
Rewards Points: 826
Re: Bubbles
I guess that analogy would make better sense if you skin was comprised of a bunch of volatile organic compounds...maybe.
Not sure about your skin, but mine is not made up of such things.
Old 01-11-2017, 12:03 PM   #26
Rewards Points: 826
Re: Bubbles
Does heat cause VOC to break down and off gas?
Tell me again how excessive heat might not bubble a finish.
Old 01-11-2017, 12:07 PM   #27
Rewards Points: 4
Re: Bubbles
My money is still on Gremlins. Short, sweaty Gremlins.
de-nagorg likes this.
getrex is offline   Reply With Quote
Old 01-11-2017, 01:20 PM   #28
Rewards Points: 626
Re: Bubbles
Now your talking! Heat is the catalyst for VOC or moisture to form a gas. Heat isn't the cause, it's an underlying problem.
You wouldn't want to put a torch to a seal container but there'd be no problem if it's under a vacuum.
Old 01-11-2017, 02:16 PM   #29
Rewards Points: 826
Re: Bubbles
I wasn't sure a more detailed explanation was necessary in this case.
And the root cause of the failure is....and still is....excessive heat.
The unless the OP can provide some more insight to indicate that focused solar energy was the main culprit and the reason for the specific location, I will defer to what is the regularly observed root cause...excessive heat via a trapped and unvented air space.
As to the specific location of the bubbles, any number of situational, material, application, and environmental factors could have affected the the outcome to create the failure in that specific location.
I will choose not to delve into an investigation that is meaningless to the net outcome and prescriptive repairs.
Strip, prep, re-paint, and vent the storm door.
Gymschu likes this.
Problem with bubbles in oil base paint ezemyr1 Painting 7 10-17-2016 06:38 AM
Paint Bubbles Moxified Painting 4 04-12-2013 08:06 AM
bubbles in new drywall mud gailquilter2 Drywall & Plaster 16 11-04-2012 07:40 AM
Millions of tiny bubbles John_W Plumbing 0 10-06-2011 11:10 AM
bubbles in tape BlueBSH Drywall & Plaster 1 11-05-2010 12:20 PM
