Bubbles - Painting - DIY Chatroom Home Improvement Forum
Like Tree13Likes
Old 01-09-2017, 11:25 AM   #1
Rewards Points: 1,479
Bubbles
This is a weird one. SW Resilience repaint. I painted this in May. It was fine all summer. Then in the fall, bubbles explode out of it. Only on the bottom half of the door. I assume it has to do with the sun and the storm door trapping heat...
mathmonger is offline   Reply With Quote
Old 01-09-2017, 11:44 AM   #2
Rewards Points: 2,822
Re: Bubbles
Blisters.
Excess heat.
ED
de-nagorg is online now   Reply With Quote
Old 01-09-2017, 11:50 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,558
Re: Bubbles
Yes.
You need to replace the glass in the Spring and put in the screen. There isn't a paint in the world that will hold up to those peak temps.
Every door manufacturer has exclusions for that.
de-nagorg likes this.
Old 01-09-2017, 11:52 AM   #4
Gymschu's Avatar
Rewards Points: 1,024
Re: Bubbles
Definitely has the look of HEAT BLISTERS. I have a customer that keeps their front door open all summer long just leaving the storm door as the only point of entry into the house. It gets so hot that it blisters the paint and WARPS the door if they leave the main door closed and trapping all that heat between the doors.
Giving us your general location helps us better help you!
Gymschu is online now   Reply With Quote
Old 01-09-2017, 08:55 PM   #5
Rewards Points: 462
Re: Bubbles
Yep, sun and a relatively dark color.
ChuckF. is offline   Reply With Quote
Old 01-10-2017, 06:41 AM   #6
Rewards Points: 700
Re: Bubbles
Has to be a better answer or more to it because the blisters don't cover the entire door.
wptski is offline   Reply With Quote
Old 01-10-2017, 06:47 AM   #7
Rewards Points: 3,897
Re: Bubbles
It is probably the angle of the sun though the glass.
There was a segment on some home show where the reflection of the sun from a nearby house actually browned some vinyl siding. It was seasonal.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 01-10-2017, 09:20 AM   #8
Re: Bubbles
I think this is less a refraction or direct exposure issue as much as it is a trapped heat issue.
Vent the next storm door properly and you should be fine.
Gymschu likes this.
Old 01-10-2017, 09:29 AM   #9
Rewards Points: 700
Re: Bubbles
Yeah that was on This Old House, I saw that two!
Gymschu likes this.
Old 01-10-2017, 09:31 AM   #10
Rewards Points: 700
Re: Bubbles
Storm doors aren't sealed that good or at least mine aren't. Still the blisters aren't all over the door meaning there is/was something else making certain areas worse.
Old 01-10-2017, 11:07 AM   #11
Anonymous Tard
getrex's Avatar
Rewards Points: 16
Re: Bubbles
Gremlins. Can't reach any higher.
chrisn and de-nagorg like this.
getrex is offline   Reply With Quote
Old 01-10-2017, 02:03 PM   #12
Re: Bubbles
With direct exposure, even a poorly sealed storm door will trap tremendous heat in a matter of minutes. We have seen doors melt the foam right out of the door in the right conditions. It certainly will have enough heat to cook the paint right off.
Old 01-10-2017, 05:03 PM   #13
paper hanger and painter
chrisn's Avatar
Rewards Points: 614
Re: Bubbles
You have been told the answer, just believe it, fix it, move on.
Old 01-10-2017, 06:17 PM   #14
Rewards Points: 700
Re: Bubbles
Fix what? I ain't the OP.
You experts haven't fully answered yet. Bubbles, blisters or whatever are what, filled with what, from where?
Heat, yeah but what's it heating? You don't fill a balloon with a vacuum!
Where's that Rick Knows Paint guy??
Old 01-10-2017, 07:43 PM   #15
Re: Bubbles
Not sure what that matters? They can be filled with any number of things but they are most likely some sort of volatilization byproduct.
Problem with bubbles in oil base paint ezemyr1 Painting 7 10-17-2016 05:38 AM
Paint Bubbles Moxified Painting 4 04-12-2013 07:06 AM
bubbles in new drywall mud gailquilter2 Drywall & Plaster 16 11-04-2012 06:40 AM
Millions of tiny bubbles John_W Plumbing 0 10-06-2011 10:10 AM
bubbles in tape BlueBSH Drywall & Plaster 1 11-05-2010 11:20 AM
