Brush Marks When Painting Roof HELP - Painting - DIY Chatroom Home Improvement Forum
Old 02-23-2009, 06:16 PM   #1
Brush marks when painting roof HELP
I am in the middle of painting my roof,Ive just put on a primer as I have galvanized iron roof and about to apply two top coats.The problem is, when Im cutting in at the edges with a brush you can see brush marks,is there a certain way to paint using a brush to minimize this effect or should I use another tool or would a more expensive brush erradicate this problem?...The brush I have at the moment is a mid-range. Thanks in advance!
Toymit is offline   Reply With Quote
Old 03-08-2009, 12:18 AM   #2
Rewards Points: 27
Try using a poly brush to smoothen out at the edges.
Determined is offline   Reply With Quote
Old 03-08-2009, 07:05 AM   #3
Remodeling Contractor
Add penetrol to oil paint or floetrol to latex paint to get a better flow. A better quality brush always helps. Better paint helps also. And on a roof? your edge may be drying to fast. Using a retarder in the paint may help that. A wet edge always is best in allowing a smooth finish.
Old 03-08-2009, 07:09 AM   #4
www.marylandpainter.net
bikerboy's Avatar
Do you see brush marks or see through the paint because you are not getting it on heavy enough? If you are just seeing through the paint, put on a second coat.
bikerboy is offline   Reply With Quote
Old 03-08-2009, 07:38 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 230
Who is going to notice on the roof?
Old 03-09-2009, 03:48 AM   #6
The easiest way to paint a roof is with a roller on a long handle. The rollers are made of plastic foam and are shaped to fit two or three corrugations. Those moulded in one piece stand up to the work better than the rollers composed of sections. There are also wire brushes for cleaning off rust and old paint that fit the corrugations.
Dana
http://www.ninaathome.com/
Dana11 is offline   Reply With Quote
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 08:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
