Brush Marks - Painting - DIY Chatroom Home Improvement Forum
Old 02-02-2008, 09:49 PM   #1
Brush Marks
Hello, I am having a problem with brush marks when I'm painting with SW ProBlock Primer. Anyways, if I paint over it with a top layer coat with their Proclassic Satin Paint / Purdy Nylon brush, will the brush marks still show?
sateke is offline   Reply With Quote
Old 02-02-2008, 10:42 PM   #2
Oldguy
Rehabber's Avatar
Any brush marks or texture will show through on paint. You can sand lightly and remove the brush marks for a better final finish
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 02-02-2008, 11:10 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
The ProBlock is rather thick
Though properly applied ProClassic enamel will hide any visual discrepancies, any actual "lumps" or "high spots" should be sanded smooth
slickshift is offline   Reply With Quote
Old 02-03-2008, 12:14 PM   #4
Pro Painter
Don't over brush, and you have to be quick especially when you use Proclassic.
TroyM is offline   Reply With Quote
Old 02-05-2008, 07:10 PM   #5
Rewards Points: 506
If by "brush marks" you mean the primer has inconsistent pigment coverage, then don't worry. If by "brush marks" you mean there are furrows in the coat, then all you have to do is give the surface a quick sanding. Primer is made to sand easily.
SirWired
sirwired is offline   Reply With Quote
spray or brush baseboards? mathdan Painting 20 06-05-2015 10:41 PM
Brush marks with Behr paints for Kitchen Cabinets...HELP!!! Torquerolljoe Painting 25 06-12-2011 08:24 PM
Spray or Brush Kitchen Cabinets?? Eric_ht Painting 18 01-06-2010 02:09 PM
Should I spray or brush? billyg Painting 5 01-24-2008 07:51 PM
Roller Marks - Please Help andru04499 Painting 3 09-16-2007 09:53 PM
