Brush Cleanup After Oil Based Paint/primer - Painting - DIY Chatroom Home Improvement Forum
Old 10-20-2013, 12:44 PM   #1
Rewards Points: 1,062
brush cleanup after oil based paint/primer
Can acetone be used for brush cleaning after oil based paints and primers? Or is it better to use paint thinner?
Old 10-20-2013, 01:24 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
You do not want to use acetone. Stick with paint thinner.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
The Following User Says Thank You to Matthewt1970 For This Useful Post:
amakarevic (10-21-2013)
Old 10-20-2013, 01:30 PM   #3
Rewards Points: 12,856
Acetone can melt the bristle's.
Old 10-20-2013, 06:42 PM   #4
cdaniels's Avatar
Regular mineral spirits works great.The white milky looking thinners-not so much.I sometimes use kerosene it softens the bristles and will clean out oil paint nicely if you can stand the smell.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
The Following User Says Thank You to cdaniels For This Useful Post:
Old 10-20-2013, 06:46 PM   #5
Jmayspaint's Avatar
Rewards Points: 534
Strong solvents can also soften the adhesive used to hold the bristles together, causing them to come out in your paint with the next use.
I hate when that happens..
Jmayspaint is online now   Reply With Quote
Old 10-20-2013, 07:57 PM   #6
Rewards Points: 5,974
Put paint thinner in a jar swirl your brush around in it and work it in to the bristles. Next put it in a jar mixed 50/50 paint thinner and lacquer thinner and swirl it around. Then a jar of straight lacquer thinner and do the same. Now rinse your brush and your done. Put the lids on the jars, the paint will settle to the bottom, pour off the top and it's ready to use again.
The Following 2 Users Say Thank You to ToolSeeker For This Useful Post:
Gymschu (10-20-2013), Jmayspaint (10-20-2013)
Old 10-21-2013, 06:26 AM   #7
Rewards Points: 4,784
Why transition to lacquer thinner? What does that do?
jeffnc is offline   Reply With Quote
Old 10-21-2013, 06:39 AM   #8
PoleCat's Avatar
Rewards Points: 1,646
I always went from thinner to dish soap and warm water.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 10-21-2013, 07:09 AM   #9
Jmayspaint's Avatar
Rewards Points: 534
It makes for a more thorough and easier cleaning. Plus, lacquer thinner evaporates cleaner than spirits and doesn't leave the brush as stinky.
The Following User Says Thank You to Jmayspaint For This Useful Post:
ToolSeeker (10-21-2013)
Old 10-21-2013, 02:19 PM   #10
Rewards Points: 394
Lacquer thinner is a hotter solvent , and is highly flammable. Mixing it with mineral spririts does not expedite the evaporation process.
Will22 is offline   Reply With Quote
Old 10-26-2013, 07:29 PM   #11
Painting Contractor CT
Rewards Points: 77
Post
Acetone will be too harsh on painting brushes, use paint thinner instead..good luck!
KD PAINTING is offline   Reply With Quote
VOC vs Solvent Staining for Fence JasonCA Painting 11 02-29-2012 04:50 PM
Brush selection for Laquer topcoat on wood trimwork crankcase Painting 4 02-18-2012 01:37 PM
Anybody still use a brush on walls? jbrady33 Painting 5 06-09-2010 06:46 AM
Brush marks when painting roof HELP Toymit Painting 5 03-09-2009 03:48 AM
Proper way to back brush bluefitness Painting 1 02-17-2009 10:34 PM
