Brick Fireplace - Painting - DIY Chatroom Home Improvement Forum
Old 07-08-2012, 10:56 AM   #1
brick fireplace
how do I whit wash a dark brick fireplace
Lois C is offline   Reply With Quote
Old 07-08-2012, 11:12 AM   #2
Too Short? Cut it Again!
Wash it and fix any defects. I would then think about using a solid color stain like Sherwin Williams Woodscapes.
Otherwise, use something like a high bond primer and glaze coats of nice acrylic finish mixed into an acrylic medium like Floetrol. Do not over thin or use water or you will destroy the properties of the paint.
Use a thick nap---1-1.5"---roller cover chase with a brush.
An alternative would be to stain or paint it to a solid white and then wipe away finish to give it a whitewashed look.
You can get solid color stain and paint of course tinted to any color. Think about something other than WHITE WHITE for the fireplace. I think white is too stark for most interiors and can make everything around it look dull and dirty instantly.
Seeking help and advice with hideous painted brick fireplace sparkler22 Painting 12 12-03-2011 07:46 PM
Can you seal brick on fireplace? mrs1885 Remodeling 3 03-29-2011 11:52 AM
Drywall a Brick Fireplace schw1927 General DIY Discussions 1 01-26-2011 04:12 PM
Fireplace Brick Veneer TV Mounting RICKM15752 Building & Construction 3 12-14-2010 05:03 PM
Brick Fireplace Paint ... g8master Building & Construction 3 12-20-2009 01:31 PM
