Boxing Around Brick Home - Painting - DIY Chatroom Home Improvement Forum
Old 01-20-2009, 06:02 PM   #1
Boxing around brick home
How do I calculate the square footage of the boxing around the perimeter of the home to get estimate a paint job?
dlarroque is offline   Reply With Quote
Old 01-21-2009, 06:18 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
The contractors should take care of that for you
If you are the contractor, then the sq. ft. will not tell you nearly enough information to submit a proper bid
You'll need an eyeball on it to see if there are any other factors that will hinder your production times, such as shrubs, gardens, pools, decks, neighbors, etc...
slickshift is offline   Reply With Quote
replacing rotten sill plate on brick exterior home S.LaRue Remodeling 11 11-02-2011 09:50 PM
Exterior Brick Wall Seperated from Home mrhonest Building & Construction 3 01-15-2009 06:06 PM
Concealed Roof Guttering on a 1930s Solid Brick Home buzzer Roofing/Siding 2 11-19-2008 07:51 AM
Shed type roof addition on Brick home? sandyman720 Roofing/Siding 6 04-24-2007 03:35 PM
