Bookshelf Paint Surface Has "orange Peel" Appearance - Painting - DIY Chatroom Home Improvement Forum
Old 09-06-2010, 10:51 PM   #1
Bookshelf paint surface has "orange peel" appearance
Just had built-in cabinet made. It is awesome. Hired a painter. He used an alkyd gloss SW ProMar 200. Even with prime coat and two topcoats the surface looks mottled and orange peel. Is this because painter used a roller nap that was too long for smooth surface? Any other causes? To fix, should I use brush or short nap roller? Is light sanding required, or can I put a coat right on top of the old?
zsquared is offline   Reply With Quote
Old 09-07-2010, 05:41 AM   #2
If I am not mistaken, Promar 200 is a latex. What primer was used? Maybe you need to read the cans if any, to make sure what was used as so others will be able to help you better.
mark942 is offline   Reply With Quote
Old 09-07-2010, 02:29 PM   #3
The ProMar 200 is an alkyd oil based paint. I don't have information about which primer was used. Even with two topcoats of ProMar still have this unwanted texture appearance.
Old 09-07-2010, 07:00 PM   #4
Matthewt1970's Avatar
Rewards Points: 1,098
According to the specs ProMar 200 does come in an Alkyd Semi-gloss, but I have never used it. You are going to have sand the poop out of it and put on another topcoat. It can be rolled, but sometimes even oil won't lay down well if rolled and not back-brushed.
Old 09-08-2010, 12:32 AM   #5
Rewards Points: 150
I bet humidity has a cause to it. Sand out smooth, apply another coat when the weather is more dry.
hammerheart14 is offline   Reply With Quote
The Following User Says Thank You to hammerheart14 For This Useful Post:
zsquared (09-13-2010)
Old 09-13-2010, 10:36 PM   #6
Being Houston in the summer, humidity may certainly be a factor. Am in the process of sanding the poop out of it. Will wait for dry weather, with good brush, a little paint conditioner and trial runs before game day.
cheap paint in bathroom got mold? mayhem69 Painting 12 05-06-2012 04:46 PM
Bad Bad Paint job to fix. Cleaning brick overspray and other problems. (Pics) ewheatley Painting 1 05-19-2009 01:08 PM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 05:50 PM
Painting a garage door dfoxworthy Painting 6 06-22-2008 10:51 PM
interior wood trim, surface preparation question copacetic Painting 3 04-25-2008 07:52 PM
