Bondo On MDF Crown? - Painting - DIY Chatroom Home Improvement Forum
Old 10-12-2013, 08:40 PM   #1
Renovating My Land Yacht
Rewards Points: 616
Bondo on MDF crown?
Put some crown moulding up yesterday (all by myself) and it looks really good even though its not painted yet. Right now its just primed.
I do have one issue though, and that is what I am calling my crown "expansion joint" (yeah I know, I know, measure twice cut once )
Gap is about 1/8th on the only butt joint in the room. Can I use bondo on MDF? I have crawfords painters putty but I am thinking that this will take years to dry to paint.
The moulding is 4 1/4 cove so no major fiddly detail to worry about.
Robyn
forcedreno2012 is offline   Reply With Quote
Old 10-13-2013, 05:44 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 310
A good caulk would be better(IMO)
chrisn is online now   Reply With Quote
Old 10-13-2013, 06:07 AM   #3
Rewards Points: 616
Morning Chris....yeah probably would have been better. Holy freakin cow that stuff stiiiiiinks. I was wearing the respirator and had a fan in the window and two blowing into the room and the house still stunk. Don't plan on ever using it again. Although it did get rid of the "expansion joint" lol.
Old 10-13-2013, 07:43 AM   #4
Rewards Points: 13,450
What kind of caulking did you use?
It should have been latex that has no smell.
Sounds like you used silicone, which can not be painted.
forcedreno2012 (10-13-2013)
Old 10-13-2013, 08:21 AM   #5
Gymschu's Avatar
Rewards Points: 658
Bondo is about the worst product you can use for wood patching/gap filling.
The Following User Says Thank You to Gymschu For This Useful Post:
Old 10-13-2013, 01:35 PM   #6
ltd
Rewards Points: 536
I like it schu not for every day ,but its nice to have a can of bondo in your van .but yes caulk it and be done
ltd is offline   Reply With Quote
The Following User Says Thank You to ltd For This Useful Post:
Old 10-13-2013, 01:43 PM   #7
Rewards Points: 512
use a drywall setting compound (easy sand 20) mix it up and fill the crack. sand it out and paint it
princelake is offline   Reply With Quote
The Following User Says Thank You to princelake For This Useful Post:
Old 10-13-2013, 02:22 PM   #8
Rewards Points: 616
Joe - I used the bondo for the bigger gap - that was the reference to the stinky stuff. The caulking is done correctly. No sillycone here :P
Prince - Thought about hot mud just not sure if it will crack later on or not.
Robyn
Old 10-13-2013, 04:28 PM   #9
chrisn's Avatar
Rewards Points: 310
Robyn
It would and so might the bondo
Old 10-13-2013, 10:18 PM   #10
Rewards Points: 121
Guaranteed to NOT crack...
We have found that using "Big Stretch" caulk (by Sasco)
for all our crown trim - at the ceiling and wall, as well as any other gaps we can eliminate the inevitable cracks. It's not cheap ($6 per tube), but when you count your time, it's worth it.
www.sashco.com/hi/bigstretch.html
I think we got ours at an Ace Hardware.
JamesRW is offline   Reply With Quote
The Following 2 Users Say Thank You to JamesRW For This Useful Post:
forcedreno2012 (10-13-2013), Gymschu (10-14-2013)
Old 10-14-2013, 07:28 AM   #11
Rewards Points: 5,974
Bondo is an absolute crapshoot especially for DIY. What's usually needed is a small to very small amount and to get the right amount of hardner is difficult, too much and impossible to sand, not enough and it stay soft. Also bondo can flash really bad.
The Following User Says Thank You to ToolSeeker For This Useful Post:
Ceiling Crown Gaps: Eliminate Via Screws? Twister Carpentry 24 08-19-2013 07:46 AM
General crown molding tips for rookies. speedster1 Carpentry 5 02-16-2010 07:18 PM
Crown Moulding and nailing davis_mc Carpentry 21 01-12-2010 10:52 PM
Crown Moulding Question lda130 Carpentry 2 11-21-2009 10:41 PM
Mixing differnet crown moldings moondog111 Carpentry 13 12-07-2008 09:40 PM
