BM Waterborne Impervo With XIM Latex X-tender? - Painting - DIY Chatroom Home Improvement Forum
Old 02-03-2010, 09:35 PM   #1
BM Waterborne Impervo with XIM Latex X-tender?
I'm planning to paint new woodwork with BM Waterborne Satin Impervo. Several people have commented that adding Floetrol will reduce brush marks. Could I use XIM Latex X-tender instead? I've heard that Floetrol will cause the paint to yellow over time, while the XIM product will not. The trim will be painted white, so this is important.
bobmg is offline   Reply With Quote
Old 02-04-2010, 03:54 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 296
The XIM is what you want to use if you have too.Be careful as the BM waterborne is thin enough IMO, and it will sag in the corners.
chrisn is online now   Reply With Quote
Old 02-04-2010, 08:45 AM   #3
floetrol causes discoloration?
The older I get the better I was
Old 02-04-2010, 06:04 PM   #4
chrisn's Avatar
Rewards Points: 296
I have never seen that
Old 02-04-2010, 10:07 PM   #5
Impervo with XIM
Some people on this forum have mentioned that Floetrol will cause yellowing over time. No experience with that myself.
Old 02-10-2010, 12:52 PM   #6
remodeling pro
I have heard a few people make this claim about Floetrol, but have never seen any discoloration that I can be confident was it's fault. I suspect the yellowing was more a result of someone using cheap white paint, which definately yellows faster than top quality brands. If you want to ease your mind, use the XIM, it is a quality brand product, and will eliminate the possibility of this brand question arising from the customer, should someone tell them this down the road.
troubleseeker is offline   Reply With Quote
Old 02-10-2010, 05:16 PM   #7
Tired, Cold, and Damp
slickshift's Avatar
Honestly, the WB Perv is pretty much as good as it gets
Any lessening of brush marks by an additive will negligible at best
If one truly needs no brush marks, then spraying is the answer
Although I occasionally use Floetrol for climate/environmental reasons, it's pretty rare
If I really wanted less brush strokes in WB Perv, aside from spraying or hot coating, I'd add some Aura Extender to it, to allow extra time for the Perv to level itself
Otherwise, I've not noticed a yellowing to FT added coatings
Admittedly I don't do a lot, but it can't possibly be as "yellowing" as oils (alkyds) with lack of sunlight
slickshift is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
Acrylic Latex Primer vs Latex Primer Saintt Painting 1 08-02-2008 09:00 PM
Epoxy Paint on Previously Painted Concrete Floor goodkarma Painting 6 07-10-2008 01:04 PM
