BM Oil Fresh Start (long Oil) - OK For Finished Trim With No Sanding? - Painting - DIY Chatroom Home Improvement Forum
Old 10-22-2013, 04:04 PM   #1
Rewards Points: 89
BM Oil Fresh Start (long oil) - OK for finished trim with no sanding?
Can I get away with painting finished trim without sanding it if I use this stuff? I was planning on scuffing and using Zinn 123 before painting, but I have a quart of the Fresh Start that I used to seal untreated wood for an exterior job and have plenty left. It's expensive so I figure I had better put it to use rather than letting it sit for years forgotten about.
There is a LOT of trim to be done so if I can avoid the scuffing step it will save a tone of time.
7.62 is offline   Reply With Quote
Old 10-22-2013, 04:10 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 316
what do you mean by finished?
Old 10-22-2013, 04:15 PM   #3
Rewards Points: 13,468
If you mean it's already painted, what's it painted with?
Old 10-22-2013, 04:18 PM   #4
Rewards Points: 89
No...I mean stained and poly'd. Presumably with oil. House is 25+ years old.
Old 10-22-2013, 04:31 PM   #5
If you want that paint to stick start sanding.
Old 10-22-2013, 06:17 PM   #6
Rewards Points: 89
But...why can I not expect the oil primer to bond well to oil poly?
Old 10-22-2013, 06:30 PM   #7
Jmayspaint's Avatar
Rewards Points: 534
The specs are going to tell you to 'dull glossy surfaces' or something to that effect.
It will bond way better if you sand it.
Jmayspaint is offline   Reply With Quote
The Following User Says Thank You to Jmayspaint For This Useful Post:
7.62 (10-22-2013)
Old 10-22-2013, 08:34 PM   #8
ltd
Rewards Points: 536
yea really ,you have to clean it ,and lightly sand ,all were talking about is breaking the gloss its easy ,just do it .can you put oil with out sanding? maybe why take the chance. a door and a frame 1 side should only take 10 min. to prep.
ltd is offline   Reply With Quote
Old 10-22-2013, 09:15 PM   #9
Rewards Points: 89
LOL, I wish that was all it was. Chair rail, baseboard and shoe, 8 door frames, 5 windows AND frames, crown. :D
Old 10-23-2013, 07:03 AM   #10
chrisn's Avatar
Rewards Points: 316
You can EXPECT all you want, but it just won't
Old 10-23-2013, 07:05 AM   #11
chrisn's Avatar
Rewards Points: 316
you need a BONDING primer, Zinnsers 123 for one
Old 10-23-2013, 07:16 PM   #12
Rewards Points: 5,974
Leave the wood and freshen up the poly.
96 Grand Cherokee 5.2L takes a long time to start renoswl Automotive Repairs 4 06-28-2011 02:19 PM
Self Leveler over fresh concrete, how long should I wait? tsg234 Building & Construction 10 03-15-2010 06:59 AM
choosing right bulb and trim kit combo for recessed windowguy Electrical 3 11-29-2009 03:17 PM
How long do I have to wait before putting tape on fresh painted wall Brandon19 Painting 6 08-29-2009 07:23 AM
Sanding my stairs. Wrong equipment? Question about removing treads. Kinda long, sorry Mike in Arkansas Flooring 3 04-23-2009 01:04 PM
