Blotchy Ceiling Using Glidden Tinted Ceiling Paint - Painting - DIY Chatroom Home Improvement Forum
Old 12-03-2009, 05:37 PM   #1
Blotchy ceiling using Glidden tinted ceiling paint
I have spent the past week trying to eliminate a blotchy ceiling without success. The ceiling is a very large area that includes the foyer, living room, and dining room (one continuous surface). I did not prime the ceiling, as I had painted it several years ago without a primer and had very good results.
I am using Glidden tinted ceiling paint (for the first time) and although it looks good initially, I have applied several coats and the blotchiness continues. I hope to avoid the agony of applying a primer and probably a different brand of paint (most likely Behr) but I may be out of luck.
I have been using a 3/8" nap on the roller and I wondered if a different length nap might work better? Any tips?
dshrewsbury is offline   Reply With Quote
Old 12-03-2009, 10:42 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
If it is just a couple spots, then buy a can of spray Bin and hit those spots. Once those spots dry, which will be pretty quick you can paint. If you used a flat paint then you can probably just paint the primed spots. Flat paint lays down and blend really well. DON'T get Behr paint. That will be jumping out of the frying pan and into the fire.
Old 12-04-2009, 03:41 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 396
If that does not work, go and get some REAL paint at a real paint store.Glidden and Behr are not good paints IMO.
chrisn is online now   Reply With Quote
Got Dark Paint on Flat white popcorn ceiling DIYAmatureLeah Painting 6 01-22-2013 06:10 PM
ceiling paint in bathroom gorilla325 Painting 15 09-10-2012 06:07 PM
Ceiling Paint CeeZee Painting 12 09-22-2010 12:07 PM
I used ceiling paint instead of primer by mistake SOCCERDAD Painting 4 03-25-2009 05:36 AM
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 10:18 AM
