Blistering Paint - Painting - DIY Chatroom Home Improvement Forum
Old 10-05-2009, 07:56 PM   #1
Rewards Points: 51
Blistering paint
I have a peculiar problem in one of my rooms. We repainted several months ago (~4-5) and today I noticed that there is an area about a square foot large where the paint is blistering. We've been working in this room since we painted it, so I know that this is a recent development.
When I felt the wall in this area, it is warm to the touch, warmer than any of the other wall areas. I looked outside, and there is nothing on the exterior wall that is different in that one spot, either. It's a couple of feet from an electrical receptacle, but the wall between it and the receptacle is cool and not blistered. Also, it's higher than the receptacle, so I don't believe the wiring goes through that area.
Suggestions?
preciouschristy is offline   Reply With Quote
Old 10-05-2009, 09:23 PM   #2
Too Short? Cut it Again!
Well something is causing the paint to lose its adhesion. Ordinarily I would think this because the surface underneath was not primed and you were trying to put latex over oil or something. It could also be a moisture problem. The fact that it is noticeably warm to the touch suggests to me there might be some sort of chemical reaction going on with the paint or even inside the wall for some reason but why it would be lasting so long is perplexing. Since you say there is no wiring in there that you know of and it is a couple feet from the outlet with cold walls in between it is probably not electrical. No water or vent lines in there either? Heating ducts in the walls for some reason? Quite baffling.
Anything generating noticeable heat would make me nervous. Hope others on this site can help you track it down.
Old 10-06-2009, 03:46 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 236
Me to
chrisn is online now   Reply With Quote
Old 10-07-2009, 11:03 AM   #4
(the original)
Rewards Points: 756
Me to
And I'll third that.... I'd cut out that section and see if there's something wrong behind it. If there isn't, then it's a chemical reaction of some kind and you need to get rid of it anyway. No telling what it might be outgassing.
ratherbefishin' is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
