Blending Paint - Painting - DIY Chatroom Home Improvement Forum
Old 03-25-2010, 10:07 PM   #1
Rewards Points: 518
Blending paint
My place was painted about 2 months ago when I moved in. They used a high-hide eggshell that looks almost flat. I was left a tiny amount for touchups which didn't quite cut it for the amount of touchups and patches I need to do. I went to the store they purchase their paint from and attempted to get a can mixed to match. They've done three adjustments and it's very very very close. At what point do I call it good and what should my expectations be? If I look at a spot I'm trying to blend straight on, it looks fine and the color looks identical. If I look on an angle I can see a small difference but I cannot tell if it's because of the roller texture or the actual color. Shining a lamp or bright LED flash light to cast a shadow shows no color difference, just bright white fixture light and daylight show a slight variance.
I'm also known to be OCD-like. Really.
n0c7 is offline   Reply With Quote
Old 03-26-2010, 02:25 AM   #2
Rewards Points: 526
it is extremely hard to do touch ups on interior walls for the reason you have surmised - differences in texture. It sounds like you have done all you can reasonably do. I would let it be for a few weeks as it could possibly 'dry down' and blend a little better. And if it doesn't and it is still bothering you, at least you will know you should repaint the walls.
Windows is offline   Reply With Quote
Old 03-26-2010, 03:37 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 224
I agree
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 05:57 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 08:18 PM
