Blending Into Existing Walls - Painting - DIY Chatroom Home Improvement Forum
Old 07-03-2006, 08:06 AM   #1
They're all fixer-uppers
J187's Avatar
Rewards Points: 516
Blending into existing walls
I have just removed two hideous shelf units, ceiling to floor, from the corners of my dining room, only to learn that the room had been painted after their installation. The previous paint is underneath. I would like to paint these sections without having to paint the rest of the walls. What is the best technique for doing this. I have found a swatch of a color that looks like a close match. I would imagine that I should avoid square lines and sand out further into a circular motion or something...
J187 is offline   Reply With Quote
Old 07-03-2006, 06:39 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
It the surface to be painted is not smooth, skim coating may help
It's a thin coat of joint compound spread out over the un-even surface to sort of re-face it...smooth it out so to speak
You'd spread it with the appropriate sized taper's knife (kinda like a big putty knife), sand it to smooth and blend, prime, then paint
slickshift is offline   Reply With Quote
Old 07-05-2006, 08:16 AM   #3
J187's Avatar
Rewards Points: 516
Thank you for your response, but I think you may have misread my post. The surface is fine - smooth, existing paint. I am concerned with matching the existing paint on the same wall. Let's say the wall is about 8 feet long, the area I have to paint is only about a 2 foot wide section at the corner.
Old 07-05-2006, 08:54 AM   #4
Oldguy
Rehabber's Avatar
Paint the entire wall, stop at the corner. the corner hides any small color change.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 07-06-2006, 07:03 AM   #5
slickshift's Avatar
Ah. I see
There's almost no way that will work with a different paint
That, however, may work
You'll have to go to the corner
Old 07-06-2006, 10:26 AM   #6
J187's Avatar
Rewards Points: 516
Originally Posted by slickshift
Ah. I see
Ok, cool. Thanks, I appreciate the info. At least now I know my plan of attack!
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
bowing walls - repair? elementx440 Building & Construction 26 03-04-2009 03:07 PM
Remodeling upper...existing runs to the basement? wease Electrical 3 02-11-2007 10:49 AM
Adding a room, footings for all walls, or just new exterior? mt232 Building & Construction 2 09-25-2006 06:55 PM
Need to Join some walls together. Need advice on a couple of things *Pics* J187 Building & Construction 4 05-20-2006 04:45 PM
