Blending Compound - Painting - DIY Chatroom Home Improvement Forum
Old 07-06-2008, 01:29 PM   #1
Blending compound
I've covered a vent opening on a wall with drywall compound. What is the best way to blend the compound into the existing texture? If I use my knife it makes little waves when it goes over the existing texture, which doesn't look very good.
Do I use a damp sponge to blend it in? Sanding screens?
I plan on going over the section with texture once sanded, but I want to make sure I've blended this well enough.
Any suggestions would be great!
k.kuenn is offline   Reply With Quote
Old 07-06-2008, 03:01 PM   #2
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 876
Yes, use a damp sponge going in circular motions.
Sir MixAlot is offline   Reply With Quote
Old 07-06-2008, 11:04 PM   #3
Rewards Points: 2,906
Ya said:
"If I use my knife it makes little waves when it goes over the existing texture, which doesn't look very good."
Why not use your knife to make little waves. Allow to dry. Then use your knife in the opposite direction to fill in those waves to achieve a flat surface. Sand smooth.
That is, allow to dry, and then sand smooth.
Nestor_Kelebay is offline   Reply With Quote
Old 07-06-2008, 11:50 PM   #4
Rewards Points: 506
With my sad DIY drywall skills, I have found it useful to use a really huge knife to keep my compound smooth. I use a 5" knife for the initial fill-ins, but the last coat I have a gigantic 10" (I' think) knife I got on clearance at Sherwin, and it makes those waves disappear, since it is much bigger than any repair I can make.
SirWired
sirwired is offline   Reply With Quote
spackle versus joint compound... joeyboy General DIY Discussions 13 01-06-2016 06:09 PM
Toping Compound for texture....before or after drywall primer? yummy mummy Building & Construction 6 05-04-2008 11:57 PM
Applying joint compound to corners DK75 Remodeling 15 04-18-2008 12:31 AM
Which drywall compound should I use? yummy mummy Building & Construction 16 11-12-2007 05:00 PM
How to deal with setting drywall compound? KUIPORNG Remodeling 11 01-11-2007 09:22 AM
