Blending Cement Ceilings In Condo - Painting - DIY Chatroom Home Improvement Forum
Old 09-12-2009, 10:56 AM   #1
Blending cement ceilings in condo
We have removed a closet to extend the kitchen. The kitchen ceiling has a smooth finish. The section we removed had stucco. We have removed the stucco and are now ready to blend the ceilings. The issue is that the existing smooth ceiling has a drop of about 1/8" and we have no idea how to get the bare cement to drop down to meet the existing smooth ceiling. Is there are product or technique that will drop the cement ceiling down 1/8" to meet seamlessly?
Maximus is offline   Reply With Quote
Old 09-13-2009, 09:22 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
The only thing I can think of off-hand is to "over-rock" the lower ceiling with 1/2" sheetrock, and the higher one with 5/8"
The tape seems (covered with joint compound) between the two should hide any (if any) leftover height difference
Not sure how you'd get the 'rock to stick to cement
Furring strips should work, but it'll lower it more than 1/8", and you'll need to shim out the 'lower side' to compensate
A drop ceiling would work and probably be easier/cheaper, but you need a fair amount of room to work one of those in...a few inches won't do it
A plasterer might be able to "fill in" the higher ceiling with a few layers
But that's beyond my area of expertise (i.e. Although I'm a devout DIYer, I'd call a plasterer for a project like that/this...I wouldn't want to have the whole thing start to fall down on me later)
Other than those, you may want to consider keeping the rise and blending it in with a subtle incline
slickshift is offline   Reply With Quote
Guidance for Insulating Slanted Ceilings - Cathedral Ceilings mdlorenz Roofing/Siding 17 09-02-2009 11:05 AM
Should I insulate Walls and Ceilings or not? williamj001 Building & Construction 6 07-24-2009 11:37 AM
Covering Radiant Heat ceilings. Hockeynews Remodeling 3 04-10-2009 09:23 AM
Texture coming off of ceilings mrswoodward General DIY Discussions 7 08-16-2007 08:42 AM
Raising The Ceilings propain Building & Construction 2 06-28-2006 06:33 PM
