Blemish On Finish - Painting - DIY Chatroom Home Improvement Forum
Old 04-02-2013, 03:59 PM   #1
Blemish on finish
Hello,
Iam painting a set of brand new oak cabinet doors, there was no previous finish on them. I used a friends hvlp sprayer and noticed little blemishes as it has dried?
what would cause this and how do i fix it?...
I used benjamin moore STIX paint to prime them.
chris1982 is offline   Reply With Quote
Old 04-02-2013, 06:57 PM   #2
Rewards Points: 13,300
Brand new oak unfinish cabinets and your painting them instead of staining
Old 04-02-2013, 07:34 PM   #3
cdaniels's Avatar
Originally Posted by chris1982 View Post
Hello,
Inexperience with a sprayer maybe? Looks like it needs sanding smooth and starting over with the finish coat.Quite possibly the material was too thin.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 04-02-2013, 08:16 PM   #4
Sand them bare? or just sand out the rough spots where the blemishes are?....
and yes....paint on brand new cabinets.....
Old 04-02-2013, 09:15 PM   #5
Looks like you have some grit in there as well. Did you strain the paint, even if it's brand new, and did you properly dust off the surface, and are you working in a clean environment? Don't assume that because a paint is fresh out of the can that it can't have impurities in it.
Old 04-02-2013, 09:17 PM   #6
Google fish eyes.
Some how your getting contamination in that paint.
Old 04-02-2013, 10:28 PM   #7
Gymschu's Avatar
Rewards Points: 490
Using a friends HVLP may have been a mistake. Was it cleaned up and ready to go? Maybe your buddy did not clean up the unit properly the last time it was used. Was it a cheaper Wagner type sprayer? They are notorious for SPITTING paint. Joe C is correct that it does look like fish eyes which can be caused by many things........it is even possible that there was some sort of contaminant on the doors before you primed them. It's always best to do a light sanding and vacuum up the dust before priming. The sanding ensures that you get any marks, wax, contaminants, etc. off the surface before painting.
Old 04-02-2013, 10:50 PM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 1,146
Contamination on the wood or in the paint or gun.....not to mention all the dirt on the doors.
Even worse....you painted them. You do NOT paint new oak. If you wanted something to paint....you use something like poplar. But, you don't paint oak.
The oak gods are getting back at you.
ddawg16 is online now   Reply With Quote
Old 04-03-2013, 04:25 AM   #9
paper hanger and painter
chrisn's Avatar
Rewards Points: 234
Who said it was oak( besides the wizard)?
chrisn is online now   Reply With Quote
Old 04-03-2013, 05:18 AM   #10
The OP,
The Following User Says Thank You to jsheridan For This Useful Post:
chrisn (04-03-2013)
Old 04-03-2013, 06:32 AM   #11
Yeah guys....I did sand them down lightly before and wipe them with a tack cloth right before spraying. So if I sand with 400 Grit and apply the primer again will that cover it? Or should I go right to the top coats and hope it covers them?
Old 04-03-2013, 07:27 AM   #12
I would sand with 220 and go to the finish coats.
Old 04-03-2013, 07:30 AM   #13
Alright thanks! Ill give it a try and let you know how it goes
Old 04-03-2013, 07:55 AM   #14
Rubbin walls since'79
Brushjockey's Avatar
Jeese- people pay me good money to paint oak all the time. And I do it without hesitation.. Now cherry- I will make a bit of a fuss. But i have painted cherry too..
Another theory is that the tack rags are really meant for oil finishes because they have a bit of oil in them to make them tacky. that could be what is causing the problem. Use a damp ( with water ) rag or even a dry wipe like swiffer.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 04-03-2013, 10:48 AM   #15
JOATMON
ddawg16's Avatar
Anyone who knows their woods can look at it and see it's oak.....oak is one of those woods that is pretty easy to tell the grain on.
And the OP said it was oak.....helps to read all the posts.....
Screen & recoat hardwood with old, possibly waxed finish? TomServo Flooring 0 10-15-2010 05:09 PM
Paint and finish advice for desk addypearce Painting 0 09-03-2010 10:03 AM
Seeking a darker finish for wooden cabinets chibear1986 Painting 8 08-25-2010 12:15 AM
Remove stain and finish from oak furniture Rohey Carpentry 3 07-30-2010 08:03 PM
Finish failure SidingHell Off Topic 5 05-20-2010 03:00 PM
