Bleeding Through BIN, Now What? - Painting - DIY Chatroom Home Improvement Forum
Old 01-17-2008, 01:22 PM   #1
Rewards Points: 77
Exclamation
Bleeding through BIN, now what?
We have been told we have "bleed thru of old nails (possibly as a result of a formerly leaky roof)". We replaced the roof.
Now were are repainting the ceilings and have applied "BIN" (on the advice of this forum's multiple posts and our paintshop) over the spots where we have these yellowish-brownish bleed thru spots. But we can still see the spots thru the BIN.
The paint store told us that "it's OK. Just paint over the BIN. The spots should not show thru the paint now." Are they correct? ...or do we need to use another/different "stain blocker" primer for such stubborn stains?
1655graff is offline   Reply With Quote
Old 01-17-2008, 01:41 PM   #2
Workaholic's Avatar
Rewards Points: 268
You should be ok to just paint over the bin as long as you got a good adhesive with the bin. Primers like bin are not made to cover the problem area by themselfs, they are made to seal the problem so that bleed through does not occure.
It should be fine as long as you did not thin the product to the point of making it uneffective. You could always put another coat of bin, yet usually that is not needed
Sean
Workaholic is offline   Reply With Quote
Old 01-17-2008, 08:07 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
BIN is the ultimate weapon against bleed through
There's none better
The area may not look "pure white" when sealed, however
Some of the stain may be showing through visibly
It should be sealed out with the BIN though (if applied properly)
And not visible after painting
slickshift is offline   Reply With Quote
Old 01-17-2008, 08:25 PM   #4
Pro Painter
Sometimes when you apply white primer (one coat) over yellowish/brownish stain, no mater what you use , BIN,SW,BM..., you may still see
through the stain.
If it is a see through, i don't think you need to prime again. Apply two finishing coats, and that should take care of your problem.
TroyM is offline   Reply With Quote
Old 01-17-2008, 08:52 PM   #5
Rewards Points: 506
Think of BIN (or other stain-sealing primers) as saran-wrap for your stains. While they won't hide the stain, they keep it from coming through to whatever you put on top.
SirWired
sirwired is offline   Reply With Quote
Old 03-03-2008, 06:54 PM   #6
Rewards Points: 77
SirWired
I wanted to get back to all of you on your advice and thank you. The BIN "wrapped" the stains, letting us paint over them with ZERO bleed thru. We were happily impressed.
Old 03-03-2008, 07:01 PM   #7
slickshift's Avatar
Thanks for the update!!
HELP: Bleeding Baseboards Roztom1 HVAC 2 10-11-2007 03:10 PM
Slow results after bleeding pipes, why? eddiefloyd HVAC 3 02-24-2007 04:54 PM
Bleeding Steam Radiator during heating season helplessowner HVAC 1 01-24-2007 12:15 PM
Bleeding my heating system 1-2-3 bwoo HVAC 25 01-02-2007 02:49 PM
Bleeding air - Hot Water Boiler Dragon HVAC 10 10-30-2006 08:13 AM
