Bleed-through With Primer - Painting - DIY Chatroom Home Improvement Forum
Old 01-17-2008, 06:41 AM   #1
Bleed-through with primer
We just primed several walls. The original, lighter-colored walls look great and are ready to be painted. The original, dark-colored walls are showing bleed-thru and the primer "finish" isn't very even. Given that this is just primer, is it a big deal? Or should we go over the dark walls with a second coat of primer?
Thanks!
stallinc is offline   Reply With Quote
Old 01-17-2008, 06:46 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 152
What was the primer? Most times you can readily see through the primer and it will be fine,but sometimes not,depends on the primer.
chrisn is online now   Reply With Quote
Old 01-17-2008, 07:33 AM   #3
Kiltz, water based primer over latex original paint
Old 01-17-2008, 07:33 AM   #4
Also, finishing paint will be Behr, latex
Old 01-17-2008, 09:58 AM   #5
Rewards Points: 506
Kilz2 (or Kilz water-base Premium) / Behr! Oh no!
Neither of those are very good products. If you didn't get the Behr custom-tinted, I'd return it to the store...
That aside, unless the primer is specifically built for high-hide, it is pretty normal for the undercoat to show through.
For future jobs, you might want to strongly consider going to a paint store (as opposed to a store w/ a paint dept.) and then buying paint at or near the top of their lines. Behr paint just isn't very consistent; sometimes it works, sometimes it doesn't.
Kilz2/Kilz Premium are just plain awful products. Kilz2 has adhesion problems (which is kind of funny, since primers are supposed to help adhesion), and Kilz Premium won't stain block worth a darn.
SirWired
sirwired is offline   Reply With Quote
Old 01-17-2008, 12:21 PM   #6
Pro Painter
I think what you have is an undercoat shows through?
Bleed through it more like when you try to paint a water damage spots on the ceiling/walls without stain blocker primer, and that yellow/brownish stain is bleed though.
Two more finishing coats should be fine.
TroyM is offline   Reply With Quote
Old 01-17-2008, 09:33 PM   #7
Tired, Cold, and Damp
slickshift's Avatar
Normally, when priming over painted walls for extreme color change reasons, the walls will not look white (like an actual paint job would)
This is normal
However, in this case I would be remiss in not mentioning a few things about the Kilz latex products
Kilz2 (latex) is a horrible sealer with little adhesion, and has extremely high failure rates (keeping in mind even a 25% failure rate means 75% non-failure...it's just who wants to take that chance)
Many real Paint Stores will not even carry this product
Premium Kilz (latex) s a little better, but not better enough for me to use or recommend it
Please return any un-opened cans and get you money back
Unfortunately I must say basically the same thing about the Behr
Contrary to public perception of the product due to excellent advertising and placement in many home improvement shows, the stuff stinks on ice
It also has problems in less than perfect conditions, and high failure rates in the field
(again, that's a percentage....that doesn't mean you can't find satisfied consumers, it just means there are way too many unsatisfied consumers)
That combined with it's general condition of being tough to work with (compared to premium paints), extremely poor coverage, needing several more coats than premium paints, and it's tendency to take months to cure make it a poor cjhoice
I would strongly recommend returning the Behr, even if it was custom tinted
If you complain enough they will most likely give you a refund or store credit
It is worth it
Really
Then go to a real Paint Store to get some real paint
You project will go quicker, smoother, with less problems, and look better when finished
To give you an idea of how bad this stuff is:
I will bid a job for a certain price, using premium quality paints
Usually Ben Moore or Sherwin Williams premium line paints (they make cheap stuff too)
If the customer wants...or rather insists that I use Behr, I will
But that raises my price about 30% - 50% more depending on the project...plus they must provide the paint (paint is included in the other bid)
The stuff is that bad...it's the only way to "cover" myself with the extra labor and problems involved...it's that bad
slickshift is offline   Reply With Quote
Old 01-18-2008, 06:17 AM   #8
chrisn's Avatar
Rewards Points: 152
Could'nt say it much better
Old 02-10-2008, 11:08 AM   #9
Rewards Points: 60
I had that problem with bleed through, and just assumed it was normal. Then I bought some Prepright/Problock primer from Sherwin Wiilliams, and it completely covered the area with no bleed through. Kilz is LOUSY!!!
spotted nikes is offline   Reply With Quote
Old 02-25-2008, 11:48 AM   #10
She'sapainter
Zennser is a good product, and normally if the wall your painting over has red tint its going to be a tough cover so you need to get something good I perfer the
Zennser Products like 123 and this has a very VOC and easy to work
A drop cloth isen't to catch paint, It's to protect what is under so wipe the drips as you go and don't track.
tverhoef is offline   Reply With Quote
Stubborn paint bleed through problem!!! DanielP Painting 15 01-02-2008 04:55 PM
Painting Bare Steel- Sand First or Use Etch Primer? scott890 Painting 2 10-11-2007 05:32 PM
Zinsser Primer on Wood Veneered Furniture cupcake Painting 3 10-05-2007 03:07 PM
Primer peeled Project Girl Painting 10 08-26-2007 04:39 PM
Is it normal for primer to show thru dark paint on first coat? Autumnknight Painting 5 10-02-2006 07:38 AM
