Black Stain For Fiberglass Door? - Painting - DIY Chatroom Home Improvement Forum
Old 08-26-2012, 12:21 AM   #1
Black stain for fiberglass door?
I am having trouble finding a Gel Stain that is black in color for a wood grain fiber glass exterior door. Is it even possible to get black??
Renae is offline   Reply With Quote
Old 08-26-2012, 05:32 AM   #2
DIY staff
Rewards Points: 7,174
I started a thread for you--I hope you find it---Mike---
Old 08-26-2012, 06:48 AM   #3
Rubbin walls since'79
Brushjockey's Avatar
The blackest are called ebony, jacobean or spanish oak, depending on brand.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 08-26-2012, 09:12 AM   #4
Rewards Points: 14,278
Is this door in direct sunlight?
Is there also a clear view storm door involved?
The reason I'm asking is most door companys have directions right on a sticker on the door or on the web site not to use a dark color.
They can get so hot it can melt the sealer in the windows, and may even distroy the finish or the door.
Might want to check this out before staining.
With a full view storm door it becomes a solor panel and it can get even hotter.
Old 08-26-2012, 09:14 AM   #5
This is absolutely correct.
lol
Old 08-26-2012, 04:54 PM   #6
But Im told if it is not a gel stain it is not recommended to put on the door. Ebony or onyx is the ideal color that I want but the darkest in a gel stain by Minwax is walnut. Do you happen to know any other brands then minwax? I have even searched the web but having absolutely no luck.
Old 08-26-2012, 05:00 PM   #7
Oh thanks for that information. We have had a fiber glass door in a previous home but the door was shaded and we had not trouble and it was stained walnut. But one of my doors will be in direct sunlight and the other will have the late noon sun. Well I'll have to alittle more researching before any stain is applied!!
Old 08-26-2012, 05:16 PM   #8
There are other sources than home depot. there called Paint stores!
A great brand is Old Masters, Zar is another one ( I actually think you can get Zar at Ace Hdwre)
Old 08-27-2012, 12:45 PM   #9
I have exhausted all stores in my city, this is a cottage that we are renovating in Newfoundland, so there are alot of hardware stores that are either not in Newfoundland or not in the city where the cottage is. But I will check in Edmonton for the brand names that you mentioned, thanks
Old 08-27-2012, 03:52 PM   #10
Many of them you can probably find sources to order thru the internet. Shipping has to be better than gas prices if you have to go a long way.
interesting patio door problems....please help. diybrad Building & Construction 6 11-20-2011 11:52 PM
black oil based solid stain ugabulldog Painting 1 11-10-2011 10:16 AM
Fiberglass door, gel stain, and nervous breakdown wit's end Painting 8 10-26-2011 10:10 PM
Rehanging an exterior basement door tputkey Building & Construction 9 05-21-2009 03:19 PM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 08:43 AM
