BIN Vs SW Primers And Sealers - Painting - DIY Chatroom Home Improvement Forum
Old 07-22-2012, 10:59 AM   #1
retired guy
igneous's Avatar
Rewards Points: 137
BIN vs SW primers and sealers
I have read numerous posts here about using Bin primers and sealers. I purchase all my paint products form SW (get a discount), but I also like what they sell. Never had any problems. What is the consensus about Bin vs SW when it comes to priming and/or sealing before painting? I will be painting a room that has been used as a playroom with markings (crayons, etc.) on the walls.
igneous is offline   Reply With Quote
Old 07-22-2012, 11:23 AM   #2
Rubbin walls since'79
Brushjockey's Avatar
The real question is what are the properties of each , and when to use them.
SW has a number of primers, each take care of different kind of problems.
BIN is a shellac ( alcohol) base- and will hold back the worst of stains and odors. Hard to work with and smelly. Dries fast.
Oil primers will hold back almost all stains, some have better adhesion, and will usually handle well and level- but you have the oil odor.
acrylic primers and primer sealers are good for new work, with proper prep can do well on existing paint, dry quick and are low odor.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 07-22-2012, 11:26 AM   #3
Try and clean the crayons (wax) off first using either cleaners that say work on crayons ( I think Krud Kutter has one) or mineral spirits. Then spot prime it with an oil primer or Bin.
Old 07-22-2012, 01:26 PM   #4
(the original)
Rewards Points: 756
SW sells a shellac primer that's a copy of BIN.
ratherbefishin' is offline   Reply With Quote
Old 07-23-2012, 02:26 PM   #5
Matthewt1970's Avatar
Rewards Points: 1,098
Yep. We have used it here and there. It does what it is supposed to;
http://www.sherwin-williams.com/pain...tings/primers/
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 07-24-2012, 03:02 PM   #6
Rewards Points: 4,796
I haven't used the SW version, but based on the ingredients I can't believe it does anything different than BIN. BIN is so expensive that I went looking for an alternative (I have a discount account at SW.) Even with the discount it couldn't beat BIN from Home Depot, so I just use BIN.
jeffnc is offline   Reply With Quote
Old 07-24-2012, 04:30 PM   #7
The bugs have been on strike ( lac bugs that is- they are the guys that really make shellac).
Caused quite a price jump!
Old 07-24-2012, 04:43 PM   #8
paper hanger and painter
chrisn's Avatar
Rewards Points: 608
When they come off strike, how much you wanna bet the price goes down?
Old 07-24-2012, 07:24 PM   #9
Paint Pro
crayons usually wont even bleed through a latex primer/sealer. shellac is overkill
Expert Paint is offline   Reply With Quote
Old 07-24-2012, 07:57 PM   #10
Crayons are wax. Might not bleed, but might roll off.
Latex over alkyd primer TVC15 Painting 15 08-14-2010 11:42 PM
