BIN Shellac Based Primer Usage - Painting - DIY Chatroom Home Improvement Forum
Old 02-18-2013, 02:38 PM   #1
Rewards Points: 12
BIN shellac based primer usage
I'll be using this product for the 1st time in an attempt to cover up some bad odor. Any recommendations on use such as gloves, brushes, eye protection , etc? TIA
diybifold is offline   Reply With Quote
Old 02-18-2013, 02:49 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
For just brushing out a couple of doors it shouldn't be too bad. It has a strong odor of denatured alcohol that dissipates pretty quickly.
Gloves if you want them, a quality synthetic brush ( but you might be tossing it afterwards) . I keep it in a sealed container with some den alcohol between uses so it doesn't get hard.
No need for eye protection unless you start flinging it around!
Ventilation or a fan indirect to give you some air is not a bad idea.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 02-18-2013, 03:27 PM   #3
Didi a little searching for BIN info for you. It is very tricky to apply because of the fast dry.
One place recommended applying with a 4" velour weenie roller. Lays down better than a foam or other type. Might be a good way to go.
Here's something blatantly swiped..
Priming With Pigmented Shellac
  • Pigmented Shellac is a very common and useful Interior Primer material... we use it everywhere! However it does not Clean-Up easily, and Alcohol is required for this! So we keep a special Paint Can with a snap-on plastic lid with a notch at the edge to allow keeping a brush in the can, in the material all the time, to avoid continuous clean-up!
  • We also recommend using old slightly worn roller covers with Pigmented Shellac, and throw them away when the job is done, to avoid clean-up!
  • Most importantly, STIR the material thoroughly to bring the Shellac up from the bottom, and apply the material SLOWLY and CAUTIOUSLY because it is as thin as water and splatters and drips easily... use Alcohol for clean-up!
  • The advantage it offers is excellent Stain Killing, and QUICK Drying (so be advised that you cannot re-brush over an area after a few minutes without "upsetting" the fast drying material)!
  • Pigmented Shellac Primer should not be used for Exterior Applications... use an Exterior Wood Oil Base Primer, or if Stains are present, use an Oil Base Stain Sealer, like Bin's Cover Stain...
  • When all else fails, read the product labels!
The Following User Says Thank You to Brushjockey For This Useful Post:
jsheridan (02-19-2013)
Old 02-18-2013, 04:43 PM   #4
747
registered
747's Avatar
Rewards Points: 534
I like those little Winnie rollers. I used one to paint my entry door.
To original poster. Just make sure you buy some denatured alcohol for cleanup. Hands brushes.
747 is offline   Reply With Quote
Old 02-18-2013, 04:52 PM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 310
ventilation, ventilation and then open all widows and use fans, it stinks
Old 02-18-2013, 07:12 PM   #6
Skip the alcohol for clean up, use ammonia. Works just the same and is a fraction of the price of alcohol.
Smoke remediation water based primer how do I know? wbwill Painting 17 02-19-2013 05:03 AM
Primer Raises Grain on Drywall Paper mobiledynamics Painting 3 04-23-2012 07:07 AM
Oil vs. Water Based Primer dzobrist Painting 9 01-17-2012 09:51 PM
Oil based Primer? Kotik Painting 2 12-06-2009 09:57 AM
using BIN Shellac Base Primer Sealer joefromcal Painting 10 05-04-2009 05:47 AM
