BIN Primer In Kitchen - Painting - DIY Chatroom Home Improvement Forum
Old 03-25-2011, 07:26 PM   #1
Question
BIN primer in kitchen
I have a '46 vintage house with a wooden tongue and groove ceiling, unpainted. I used BIN primer (oil base) on it and it came out wonderful! I like the bright white so much, I was wondering if I can just leave it as is or if I have to paint over it for some reason? There might be a reason I haven't thought of. Thanks!
sheila917 is offline   Reply With Quote
Old 03-25-2011, 07:52 PM   #2
Hi sheila, BIN primer, the proper primer for t/g, is a shellac based product, not oil. It reduces with denatured alcohol as opposed to paint thinner. As to your question, I don't think I would leave it unfinished because I think in time it will discolor. What I would do is do a BIN sample, couple of coats, on a piece of wood and take it to a paint store, not HD, and tell them you want the closest match in color and sheen and you should find something that will imitate the look you have now, and be more appropriate for the long term. Good Luck.
The Following User Says Thank You to jsheridan For This Useful Post:
sheila917 (03-25-2011)
Old 03-25-2011, 08:03 PM   #3
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
You should paint it. Primer provides adhesion for the paint and also provides for uniform color. Paint is what actually protects the surface. Like Joe said if the primer is left unpainted it will probably fade over time , but it is also not protected. Most primers are suppose to be painted in the range of 15-30 days after priming. Joe had a good idea about making your sample on a piece of wood and bringing it to a real paint store.
housepaintingny is offline   Reply With Quote
The Following 2 Users Say Thank You to housepaintingny For This Useful Post:
jsheridan (03-25-2011), sheila917 (03-25-2011)
Old 03-25-2011, 09:41 PM   #4
I'll paint it tomorrow (then I can finish the rest of the kitchen)! I guess because I've lived with that dark dingy ceiling for a year (when I bought the house), it's sooooo nice to have the brightness of the white!
Thanks for your exper-tese (sp?), it's appreciated!
Sheila
P.S. Joe, does that mean I need denatured alcohol to get this stuff off my arms and whatever is on my face/glasses - haven't looked in the mirror yet LOL? I asked at HD and she said thinner would work...hummmmmmm
Old 03-25-2011, 09:58 PM   #5
Sheila, read the back of the can for where it says clean up. BIN is a Zinsser product and is shellac, but Zinsser makes a product called Cover Stain, which is an oil product. But, cover stain doesn't have "BIN" on the front. BIN cleans up with denatured alcohol or ammonia. It comes off my skin with a rag in the shower, so the oils in your facial skin should make it somewhat easy to remove with a wet terry rag. Clean your glasses with whichever you have. Take Care.
Joe
Old 03-26-2011, 04:22 AM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 124
Sheila
Well, if it is BIN, thinner will not work
Old 03-28-2011, 01:09 AM   #7
Matthewt1970's Avatar
Rewards Points: 1,098
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Fresh acrylic primer + paint not sticking paul_l Painting 12 09-23-2010 10:06 AM
PVA Primer Disaster bobcatm Painting 1 08-17-2010 01:41 PM
New floor/subfloor in kitchen. Need ideas DanBress Flooring 3 10-20-2008 09:31 PM
Painting Bare Steel- Sand First or Use Etch Primer? scott890 Painting 2 10-11-2007 05:32 PM
