Bin Primer 123 Plus - Painting - DIY Chatroom Home Improvement Forum
Old 07-05-2010, 07:08 PM   #1
Bin Primer 123 Plus
I have used the Bin Primer (with shellac, red label) on varnished cabinets, followed by paint and then a waterbased polyurethane and I've had great results. I just saw that Bin has another primer that's 123 Plus used for interior and exterior. I'm wondering if this one will be any better than what I have been using since it's for exterior too. My only concern is that it is not shellac based as the other Bin primer. I'm going to use it the same way as before; primer over varnished cabinets, followed by paint and polyurethane.
Rausch is offline   Reply With Quote
Old 07-06-2010, 06:01 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 124
Bin is a Zinnser product, as you said, it is shellac based and usually used for very bad stain coverage, not necessairly used as a primer for normal painting projects, not needed.
123 is a Zinsser product, a good stain blocker and all around primer, better for what you are doing and the smell will not kill you outright.
Old 07-06-2010, 10:54 AM   #3
Rewards Points: 252
the 123 plus (also called Smart Prime) is a nice product. The only problem I have found so far is that it does not cover all water stains - as it claims.
mazzonetv is offline   Reply With Quote
Free 5 gl of Behr Primer: Why Shouldn't I use it? Lovegasoline Painting 18 10-12-2013 08:47 AM
primer not adhering to drywall texture? eli_carson Drywall & Plaster 13 07-25-2013 09:00 AM
Primer for vinyl covered wallboard a new DIY-er Painting 0 02-20-2010 07:29 AM
help me pick a primer jheavner Painting 21 01-27-2009 12:30 AM
Painting Bare Steel- Sand First or Use Etch Primer? scott890 Painting 2 10-11-2007 05:32 PM
