Old 04-07-2008, 08:19 PM   #1
Between coats of polyurethane on wood floors, how do you get up the dust?
I'm in the midst of refinishing my wood floors. I've stained and applied the first coat of polyurethane. It says to sand with 220-grit sandpaper just before applying the second coat of polyurethane. Now, what's the best way to get the dust up from this sanding? I've read that you can use a vacuum cleaner, but to me, that seems too heavy for the floor at this point. What about a cloth damped with mineral spirits? Or would that hurt the floor's finish???
proofer is offline   Reply With Quote
Old 04-07-2008, 08:27 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Tack cloth
slickshift is offline   Reply With Quote
Polyurethane on wood floors -- What is this "wet edge"? proofer Flooring 1 04-06-2008 09:08 PM
Minwax Polyurethane vs. Minwax Polyurethane Floors proofer Flooring 3 04-06-2008 09:48 AM
Staining Wood Floor -- Use Polyurethane or FLOOR Polyurethane? proofer Painting 2 04-05-2008 08:47 PM
Need some advice on how to remove ceramic tiles over wood floors. sandman512 Flooring 4 09-02-2007 12:03 PM
Washing my wood floors J187 Flooring 1 11-14-2006 11:13 PM
