Old 07-24-2008, 01:37 PM   #1
Best way to texture a bathroom ceiling
Unfortunately my bathroom project is too small to attract a good drywall mudding contractor in the tight Alberta labour market I live in and I will therefore be doing my mudding myself. I have some mudding exposure so I am confident that as long as I don't rush myself, I can do a decent job on the walls. But when it comes to my ceiling in my bathroom I am not sure as to what is the best way to tackle this task.
So ...
What is considered the best way to texture a bathroom ceiling? Is there some sort of compound I should be adding to the hopper to ensure the ceiling doesn't drop in the moist bathroom environment? Or is it a case of using an acrylic paint on the ceiling after it is textured? Inquiring minds need to know ... thanks in advance.
DIY-Renovator is offline   Reply With Quote
Old 07-24-2008, 02:17 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
The best way to avoid moisture issues with textured ceilings in a bath is to use premium quality acrylic primers and bath paints
...actually the best way is to not texture it
Ever try and X-14 a moldy textured ceiling?
Bleah...
slickshift is offline   Reply With Quote
Old 07-29-2008, 05:06 PM   #3
Drywall contractor
I'd have to agree. Slick finish is your friend if you expect any problems. Whether it's just cleaning or a patch, slick is the easiest to deal with.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 07-30-2008, 10:49 AM   #4
I have been mudding and sanding this week in my new bathroom with mixed results. I used a formal "taping" mud for my 1st coat and overall this coat was not that bad. My mud mixed seemed to get dry at the end of the job, but fortunately the end happened to be in the location where the bathroom vanity will conceal any nastiness. My 2nd coat was with a formal "finishing" mud and while I don't think I did any damage, it was not the best mix. Yesterday I did a 3rd coat (thinking it was more like an experienced mudders 2nd coat) and my mud mix with water was nice. You could tell the way it was going on that I actually did something right. Parts of my room can be considered done (I won't know until I sand later today) and I know I have at least one part of a corner that will need more work, plus I still need to make my horizontal joints wider. So parts of the room will get a 4th and who knows ... LOL ... maybe even more coats. But with all this said, my ceiling seems to be coming along okay. I will know more later today after I sand my latest application, but I suspect my problem areas will not be on the ceiling. Still not sure if I will be able to go flat there, but I guess I will know more once I sand the ceiling and the first coat of primer is applied.
ceiling paint in bathroom gorilla325 Painting 15 09-10-2012 07:07 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Texture Ceiling Ideas - New Sheetrock Stargazer Remodeling 5 10-31-2008 08:12 PM
Soffit Running Thru Bathroom / Dropped Ceiling xlr8tn Building & Construction 3 01-23-2008 07:37 PM
excessive moisture on bathroom ceiling Den69RS96 General Discussion 8 01-14-2008 09:37 AM
