Old 07-31-2006, 04:28 PM   #1
BPP
Best Way to repair visible drywall seams/taping before painting?
What would you guys recommend repairing visible taping at certain drywall seams (this is mostly in the stairwell). The taping actually protrudes from the wall and the wall is painted/primed from when I originally purchased. Should I try to sand it down and then apply mud. Or would it be better to just apply mud and try to even it out. I guess another option above that would be to try to pull out the tape if possible and the retape/remud. I am a perfectionist so any visible taping would annoy me.
BPP is offline   Reply With Quote
Old 07-31-2006, 04:52 PM   #2
Is this a bubble, the edge of the tape or just thin compound?
redline is offline   Reply With Quote
Old 07-31-2006, 05:20 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
I'm not sure if it's protruding like it was never 2nd and 3rd coated with mud, or protruding like it's peeling or popped up
For number one it would be better to put the 2nd and 3rd coats on and sand and prime
For number two it would be better to cut it out or pull it up
Then proceed to patch- or re-tape and mud it
slickshift is offline   Reply With Quote
Old 08-01-2006, 11:12 AM   #4
BPP
The drywall seam has a ridge that you can see and feel where they had taped. Its basically slightly raised and you can see horizontal line where the drywall was taped.
Old 08-01-2006, 01:04 PM   #5
They're all fixer-uppers
J187's Avatar
sounds like it was sanded too much after it was taped. You may be able to just apply more coats, do you have the room to feather out the mud or are you up against an obstacle like another wall or molding or something?
J187 is offline   Reply With Quote
Old 08-01-2006, 03:36 PM   #6
BPP
There is easily enough room to feather some mud. Thats what I was thinking about doing but wanted to see if try to sand it down and then mudding. Thanks!
Old 08-01-2006, 04:44 PM   #7
J187's Avatar
If you are already seeing tape, definitley don't sand any more until you mud. Unless you have a little bit of paint that you want to take off before you mud, otherwise don't try to sand the compound spots if tape is already showing. I think a couple coats of mud will cover it right up and as long as you can feather it pretty well, you'll never know the differnece.
Old 08-01-2006, 10:09 PM   #8
slickshift's Avatar
I agree
That's what I'd suggest
Garage drywall painting haylo75 Painting 18 11-12-2007 09:13 PM
Drywall Painting Question WorkOnIt Painting 8 06-14-2007 05:12 PM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 06:33 PM
painting over drywall -- what kind of prep? CindyF Painting 6 01-12-2006 01:54 AM
Painting drywall in garage Rod Painting 5 08-12-2005 07:36 PM
